Question about Biostar U8668 (U8668DV7) Motherboard
Wont read my usb hardrive - Biostar U8668 (U8668DV7) Motherboard
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Not reading external hardrives
Does read anything else? perhaps usb port is disable in the bios settings
what operating system are you using?
try smaler usb flash see if reads that
Jul 24, 2012 | Sony Playstation 3 (PS3) Console
Hi my blue light for the external hardrive turns on all the time but my computer just wont detect it \r\ndoes this mean that my hardrive doesn' work anymore? is there anyway i can all my files bac? thank...
If it used to read it, but doesnt anymore, could be a sign of a hardware failure. If another computer reads it, then it is probably a driver issue. Try to turn the power on, then insert the USB cable into the computer.
May 03, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Hi, I just pruchased an NBox RMVB HD Media player. I have tried playing movies from my Seagate 1TB hard drive thru the media player on my HD TV but it is unable to read my hard drive however I have played...
you could try formatting your hdd to fat32 also some times this media player has probs reading certain codecs and i also noticed that when a hdd is too full it does tend 2 play up a bit well they say for a hdd to run properly you got to have at leased 15% of free space also there is firmware upgrade out there for the tvd version of this player that works gr8 hope this helped you out ka kite
Oct 21, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
My computer wont read my Simpletech 500gb hardrive
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
External hardrive wont transfer data
looks like the usb connection pins are not touching the other connection pins. just check the pins touch each other surface then the data will transfer. check all four pins. if it is a standard A connector then far two pins are power supply and middle two pins are data pins.
v- data- data+ v+
the above are the pins in a standard usb connector
Apr 19, 2009 | Computers & Internet
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
External Hardrive crashed
Try reading this post........http://forums.macosxhints.com/archive/index.php/t-32880.html
Jul 18, 2008 | Computers & Internet
Hardrive not recognised my computer yet the power light is on
go to control panel.. go to Administrative tools.. then .. go to computer management.. on the left pane.. click disk management.. u can detect all ur drives in here including those who are not seen by your MY COMPUTER..
Apr 13, 2008 | Computers & Internet
Hard drive
Try going into setup and make sure the computer know it is there.
Dec 16, 2007 | Dell OptiPlex GX150 PC Desktop
Biostar U8668 (U8668DV7) Motherboard Logo
15 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
