Question about Ovens
GE Truetemp model# JGBP35BEA2BB; Broiler and range work fine, oven does not light.
  • 2,382 Answers
Hi, if this is a GAS range, the majority of the cases this problem is attributed to a bad igniter on the bake manifold. Each oven manifold (one for bake, one for broil) has its own igniter. They are both fed from the same gas source, though. So, if the broiler works, more than likely you simply need to replace the bake igniter. The following LINK explains....
The bake igniter tends to wear out faster, due to the frequency of use.
You can purchase replacements on line at searspartsdirect, appliancepartspros, pcappliancerepair, or repairclinic. Just use you model number as your search criteria.
This is a simple repair that anyone can do on their without the need of a service call.
Posted on Sep 08, 2010
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
GE Range...oven problem. Oven turns on but doesn't preheat to set temp. The broiler burner works fine.
Check resistance of lower burner ignitor. Should be above 4ohms. If not, replace. Part 40-75$ + labor. Let me know if info helps- ED
Mar 02, 2010 | GE Ovens
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
GE oven bake igniter is bad ?
Yes, it should work fine to swap them. (fortunately the bake and broil igniters are often the same part number on GE gas ranges, as as opposed to many other brands) Of course now you broil will not work, but you should be able to get your oven going again.
Jul 15, 2009 | Ovens
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
80 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
