Question about Labtec LCS 2424 Computer Speakers
I have a a Labtec Multimedia Speaker, Pulse 475, that I have had for years. All of a sudden, one of the smaller speaker connections does not work. Both satellite speakers work fine but only when they are plugged into the white hole. The red hole is not functioning. The wires are still solidly connected inside the speaker. Any suggestions?
cTech1
  • 66 Answers
SOURCE: labtec 1070 speaker wire is shot
It looks like this wire is not replaceable. The good news is you can get another pair of these exact speakers for 8.99 us. here is a link for that :
http://www.mypcbee.com/cat1186.html
Posted on May 15, 2008
  • 4 Answers
SOURCE: labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Posted on Feb 08, 2009
  • 241 Answers
SOURCE: wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Posted on Sep 07, 2009
Testimonial: "Totally what I needed. Thank you very much for your help! It's my first day on a website like this and I'm a believer already.. "
SOURCE: Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Posted on Jan 23, 2010
SOURCE: No left channel output from
Audio output chip TEA2025B. I'd replace both. http://search.digikey.com/scripts/DkSearch/dksus.dll?site=us&lang=en&keywords=tea2025b
Posted on Feb 14, 2011
How do I install my Labtec Pulse 375 Flat Panel Stereo Speaker System
Based on the color-coded audio cables that came with the speaker system, connect one of the AUDIO OUTPUTS set on your audio source (TV, PC) to a corresponding AUDIO INPUT set on your speaker system.
Nov 22, 2014 | Labtec Audio Players & Recorders
No sound
just remove the speaker wire from computer and check some other speakers with it like headphones if sound is there or not???if yes then might be problem with your speakers if not then you have to update your sound drivers...for that you can use softwares like driver genius it is really a good software...
Jan 06, 2012 | Labtec Pulse 485 Computer Speakers
Just reformated my computer and now can not get the speakers to work . I do not have an install disc. What can i do to fix this problem?
gfo to the computer manufacturer's website and look up the computer by model and/or serial number, and download the proper "audio driver" for your operating system. it may be alternatively labeled as "ac97" or "realtec" or possibly something i have never heard of.
Nov 06, 2010 | Labtec Pulse 475 Computer Speakers
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
Dont have disc to install
Hi,are there any drivers for that piece of hardware? It does not look like. There is only a users manual on Labtec.com .http://www.labtec.de/index.cfm/gear/details/APAC/EN,crid=18,contentid=635,crid2=22
Jun 15, 2009 | Labtec Pulse 475 Computer Speakers
Speakers
  1. first findout the problem is due to speaker or from your computer soun driver or hardware.
  2. for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
  3. check the computer sound driver software may installed properly
  4. for these type dxdiag on run in the start menu
  5. check the sound driver problem, if it re install the sound driver by using its cd
Jan 18, 2008 | Labtec Pulse 285 Computer Speakers
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
Labtec LCS 2424 Computer Speakers Logo
43 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
