Question about E-Machines etower 500ix PC Desktop
Today, power went out, back on a few seconds later, 10 seconds later out, 5-6 seconds later back on, 5-6 seconds later power was out for a couple hours. When I turned my etower 500ix back on, it ends up aborting rendering a blue screen saying at the top: ***STOP: 0x00000007B (0x8189E030), INACCESSIBLE_BOOT_DEVICE If this is the first time you've seen this Stop error screen, restart your coputer. If this screen appears again, follow these steps: blah, blah, blah...Refer to your Getting Started Manual for more info on troubleshooting Stop errors. I don't have the Start Manual anymore, but I can't get my machine to boot properly. What the "Power" outage did, I can't figure out. I was able to get into Safe Mode, but it can not re-boot. It just goes back to the blue screen. I don't want to lose all the accounting work I had on.....Ouch!!!
  • mreisner26 Sep 09, 2010
    I did have some data backed up on a 4G flash - some. I have been able to get into AMIBIOS Setup, but can't establish Hard Drive Types, Cyl, Hd. WP, or Sizes (MB). Sec is 17 on Pri-Master, Pri-Slave, Sec-Master
  • mreisner26 Sep 22, 2010
    I pulled my hard drive, Booted from Windows OEM CD into recovery console. I repaired the Master Boot record and Boot partition for the active partition. While in Recovery Mode, executed a check disk of the complete Hard Drive. Repaired multiple bad sectors on the hard drive. System now boots properly. PULLING MY HD AND ATTACHING TO A COMPATIBLE MACHINE ALLOWED ME TO GET RID OF THE 'BLUE SCREEN'. ALL DATA WAS SAVED.
    Brigadier General:
  • 4,044 Answers
The spikes caused by the power drops messed up you boot sector. You can most likely download the manual you need from E-Machine but unless I miss my guess it is going to take you through the format and software load options which means your basically starting the machine from scratch and you will lose the data you have on that drive. Get a UPS and surge protector as soon as you can to put on this machine. If nothing else you can get a small one from Walmart or best Buy for $30 to $40 that will at least supply power long enough for the tower to shut down properly in these situations.
Posted on Sep 08, 2010
  • James Young Sep 10, 2010
    AMIBIOS has an Auto Detect function for the hard drives. Assuming they are installed using a controller built on to the motherboard. If they were installed using a separate Controller card which was installed in an expansion slot, check the controller card. You won't get anywhere until the machine recognizes the hard drives and will read them. As far as the machine is concerned they don't exist until they are setup in BIOS.
  • James Young Sep 22, 2010
    Sometimes that does work but the majority of the time it does not. I am concerned that you found Multiple bad sectors that had to be repaired. It is important for you to note that the repair process doesn't actually fix those. It simply marks them as bad in the Master Boot Record and does not use them. There is something physically wrong with your drive and your problem is going to get worse over time and it will generate more bad sectors. You should get a replacement drive and back up all your data and remove that drive before it becomes critical. This is especially true if any of those bad sectors were located in the Master Boot Record. I am glad you were able to recover your data and drives. Good Luck in the future and I sincerely hope you have no further problems with this Drive.
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
Today the TV just turned off by itself. I
Its your STK ICS STK 392-110s are Factory ICs use STK392-150s Call Mats 1-800-628-1118
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My rca r52wh74 turns on for 10 secs then off.
was the storage unit climate controlled? If not then it's most likely due to heat and or humidity in which case I would suggest cleaning out the tv from the inside if you want to spend the time to do so but there is a good chance that the tv will need to be replaced.
May 31, 2009 | Televison & Video
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Picture flips from color to black and white continuously
I believe your set has a loose conection that needs to be resoldered ,every time you hit it reacts and that is good,you need to use a wooden or rubber handle to tap in the main board,around the tuner and in different areas until it reacts,be attentive when it does so you can flip the board and resoldered the area that made it react,once the problem is corrected you need to resoldered any other overheated areas and there should be a few in your set,check the grounds in the tuner(where the coax goes in the inside,is a silver box),the horizontal driver transformer and output transformer.Be careful while you do this and stay away from the thick red wire going to the back of the picture tube specially when the set is on. Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sony KV-32FS13 TV
E-Machines etower 500ix PC Desktop Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
