Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor Dual-Fuel 30" Range. ERD30S06ch) Oven controls work - Oven has poser, I can set the temperature, fan come on - but oven does not heat up. No heat at all. Please help. Thank You. VT Oliveri
  • 100 Answers
SOURCE: Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
Posted on Nov 03, 2007
SOURCE: Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Posted on Dec 20, 2007
This solution worked for me. My gas oven would not work even though my burners would. There were 6 screws to undo and I removed the screen that led to the thermostat. Note: the reset button is located on the top of the thermostat and is red (actually is a square red button) - it is behind another round metal disk (that you first will see after removing the metal screen) with wires plugged into to but if you look from the front side view you will see it behind the disk. I reached back with my finger and pressed it down to reset. Thanks all for this great tip - saved me a service call!
Posted on Dec 24, 2007
Krazytech
  • 725 Answers
SOURCE: Dacor Epiente 36"Range Oven Contrrol Panel won't work.
does the clock work? try a hard reset (turn off the circit breaker for 1 min .. then turn back on or you can also check TCO you under the grille be sure to turn the power off
Posted on Aug 24, 2008
  • 15 Answers
SOURCE: GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
Dacor range ERD30S06CH baking element doesn't heat
Hello Laura Crupi,
Not finding Dacor parts in the usual places
(pretty appliance though)...
it looks to be called a "butterfly" element.
I will post a VIDEO that shows how to test it
for continuity...
I HAVE not found anything that shows if it wires
or PLUGS IN... so I will say now... If you disconnect any
wire... for any reason... MAKE SURE YOU PUT AN
ALIGATOR CLIP on it before letting go...
One of the biggest known OVEN REPAIR issues:
LOOSE WIRES retreat back inside the OVEN SHELL...
THEN the ENTIRE OVEN has to be taken apart to
fish that wire back trough the right hole...
Just don't let ANY WIRES get loose.
Alligator clips... hemostats.. & Bell System 419A
test clips can all save an entire afternoon of grief.
(((seriously))).
Dacor ERD30S06CH
62628 Dacor Bake Element
https://www.youtube.com/watch?v=X8w1w45TrnU
Normally I don't recommend SEARS... but your pictures & prices vary wildly... Nevermind ... $156
BEST... repair clinic (with support video)
Bake Element 62628
Carnac the Magnificent
May 26, 2017 | Dacor Kitchen Ranges
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
F3 error. Beeping wont stop.
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 21, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Hi - the Dacor ERD 48 oven doesnt heat to the set temperature - usuakky 25 - 50 degrees below the set temperature. Any idea how to correct this?
Read the troubleshooting tips on the below link as it might be helpful in solving the problem;
http://www.partselect.com/range-stove-oven+Element-Heat-Incorrect+repair.htm
I hope the above helps. If it doesn't, please let me know so that I may direct you further.
Good luck.
Jan 04, 2011 | Dacor Epicure ERD48 Dual Fuel (Electric...
I have a code on my Dacor range model R50305 and the oven wont work. the code is FO. It is a dual fuel model and the stovetop still works, but not able to turn the oven on.
Your clock button is stuck.
Push it several times to dislodge it,then turn off the range power for 30 seconds and plug it back in.
This may correct the problem.
Otherwise you will have to replace the electronic control.
Dec 01, 2010 | Dacor Kitchen Ranges
How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
109 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
