Question about Cycling
I have 7 gears on my mountain bike, but when I shift into 7th gear it doesn't shift at all. How do I fix it so I can get 7th gear to work? Thanks, R. J.
  • 186 Answers
THE REAR DERAILIER HAS 2 SMALL SCREWS. UNSCREW ONE OF THEM MORE.THIS SHOULD ALLOW THE DERAILIER TO MOVE OVER MORE
Posted on Sep 14, 2010
I have a 21 speed mountain bike. it was wrecked, and now my front gear derailer is not locking into position, it always returns to the first gear unless i hold it in gear. any quick fix solutions as i...
The answer is to tighten the shift handle. The resistance to movement is inside the actual shift knob - it may be worn (tightened again and again) until there is no take up. Usually, you can turn the screw that holds the shift handle on, to tighten it. The pivot screw holds a One Way Clutch to assist in selecting gears.
I suggest that you uncrew the shift screw and add a small peice of paper to the "stack" to increase total width. Then you can turn the screw (at the pivot point) to increase friction of the handle.
Jul 27, 2011 | Cycling
My gears are slipping. how can i adjust them? the problem seems to be more in the 5th, 6th and 7th gear. this is a schwinn ranger mountain bike 2.6. it actully just started giving me a problem.
Sounds like your cable has stretched a bit and now the tension is off. There is a barrel adjuster where the cable comes into the rear derailleur. Turning this barrel too the right will increase the slack and turning it too the left will take up some slack.
Shift your gears to the middle of the cassette, then try turning the barrel 1/4 turn to the left, shift and see if it shifts into gear, if not shift back and adjust the tension again. Keep repeating till the gears line up.
if this does not work then it's time to take into a bike shop.
Apr 23, 2011 | Cycling
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
My mountain bike has a gear shifting problem.I can't shift to 1st gear. please help
There are 2 screws one which sets the limit of how far out and the other how far in the derailleur can move. This is to stop the chain coming off either side of the casette. If you get a friend to operate the gears while you watch the derailleur you'll see the screw that's blocking it from moving out far enough for first gear. Adjust the screw so it can move out further and it should solve the problem.
Dec 04, 2010 | Columbia Sportswear Columbia Anzer Peak...
Have a trex 7.2 it is new shifts great but when I shift from 5th to 6th it starts to slip a little but when I go to 7th gear it is not useable . slips so bad . This is the second fx 2 , the first one did...
This is a matter of adjustment so the shop shoudl be able to fix this for you. Cable will always stretch on a new bike so these issues usually arise after a few rides. A good shop should tell you this when you buy the bike and have you come back for some adjustment at a later date.
Jun 11, 2010 | Montague Paratrooper Mountain Bike - 20"
How to operate the gears and shift , I got the bike givin to me no manuel all I know is the it looks to be in good shape
log onto trek.com and go to support. Shifting gear isw simple enough just press the bottom shift to go up nto easier gear and pull on top shift to go to higher(harder) gear
Mar 21, 2010 | Mountain Trek Bontrager 24 Spoke Radial...
My bike has 21 gears the new wheel only has 18 gears w ill the bike work
yes it will. You will have to adjust the gear shift cable so that it doesn't go past the 6th gear on the wheel (as you would've had a 7th gear) otherwise your chain will constantly slip off the wheel and jam up
Sep 30, 2009 | Cycling
Cycling Logo
104 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
