Question about Microsoft Broadband Networking MN-700 Wireless-G Base Station (L21-00011) Router
Wireless base station will not hook up through port 1 or 2 only through 3 and 4 1 and 2 do not light up when plugged in but 3 and 4 do. shows network cable unpluged when plugged into 1 and 2. shows connected when plugged into 3 or 4. bad router?
    Brigadier General:
  • 4,044 Answers
Yes, bad router.
Posted on Sep 08, 2010
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
Mar 03, 2014 | ASUS Us Rtn53 Dual Band Wireless Router...
Blinking yellow light
Does your mac have an ethernet port? If so, try hooking it up and see what happens. This would eliminate any other issues other than it being a wireless problem . . .
Sep 09, 2012 | Apple AirPort Extreme (AIRPORTEXTREME)...
Someone helped me hook up my dell laptop to the airport exteme wireless. The wireless is on the actual new laptop, but it asks for a security key. I have no idea what the security key is any ideas? ...
If your network is being created by an Apple AirPort base station, use AirPort Utility to put the base station into "manual setup" mode, then pull down the "Base Station" menu and select "Equivalent Network Password". Try the value shown there.
Oct 13, 2010 | Apple AirPort Extreme Base Station
I have cable internet but it will not recognize MN 500 base station for internet
You need to perform MAC Address Cloning. Make sure the physical connection is fine. From modem to internet port of router, from pc to port 1 of the router as well. Now open the admin page of your router and look for MAC Address Clone settings. You have to enable it and click on Clone. Save the settings and power cycle your device for 1 minute.
Jun 26, 2009 | Microsoft Broadband Networking MN-500...
Cam won't work over internet. using the microsoft wirelessMN-500
You'll needing to access the configuration page of the router? if you are using a router on the network. The IP address (Example 192.168.0.1) under on the advance tab you will a port forwarding to open the ports of the MN-500 wireless base station.
Note: you'll needing to call your wireless base station manufacturer to gather the ports to open on the router.
Mar 10, 2009 | Microsoft Broadband Networking MN-500...
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
Sph200d not getting ip address from router
I had the same problem. I set up a static address instead and it works very well. I just copied the details form my laptop, diabled the laptop and set up the phone with the same details as I had on my laptop. Once I start the laptop again, it will get another address. --Jonas
Jul 23, 2008 | NetGear SPH200D IP Wireless Phone
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
When i hook up the router i have connection at the computer side but
There is the possibility that there are too many users of the same wireless channel in your area or that your wireless phone base station is too close to the router and is interfering. Move the wireless phone if necessary. Then in the router there are configurable channels for the radio communication channels 1, 6 or 11 are preferred. If you see other routers in the area and it shows the channels they are using choose a channel probably 1 or 11 that they are not using. If the first try does not work try the other.
Jan 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
How to update the firmware and software for my Microsoft Broadband Networking device
Back up base station settings Before you start, back up the current settings for your base station. To do this, follow these steps: 1. Start the Microsoft Broadband Network Utility. 2. On the Tools menu, click Management Tool. 3. When you are prompted to, log on to the base station. To do this, use the password that you created when you ran the Setup Wizard the first time. If you did not run the Setup Wizard, use the following default base station password: admin 4. On the Management menu, click Back up and Restore Settings. 5. Click Back Up Settings. 6. Click Save. 7. Type a name for the file that contains your base station settings or use the default name Config.bin. 8. Click the folder where you want to save the file, and then click Save. Back to the top Back to the top Disable firewall or antivirus programs For information about how to disable your firewall or antivirus programs, view the documentation that came with the program, or contact the manufacturer's technical support. Back to the top Back to the top Install firmware update Warning Do not install the firmware update from a computer that is connected to your base station by using a wireless network connection. If your wireless signal is interrupted, weakened, or interfered with while the firmware update is running, your base station may become unusable. Automatic update 1. Start the Microsoft Broadband Network Utility. 2. On the Help menu, click Check for Updates Online. The Broadband Networking Update Service checks for updates by connecting to Microsoft. This can take several minutes, depending on your connection speed. If any new updates are available, a download screen appears. Otherwise, you receive a ?No new updates are available? message. 3. Follow the instructions on the Broadband Networking Update Service page to update the firmware of your device. If the automatic update fails, go to the "Manual Update" section. Manual update 1. Download the MSBNDownload.exe firmware update. To do this, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?linkid=6... (http://go.microsoft.com/fwlink/?linkid=6790) 2. Save the file to a location such as your desktop or the My Documents folder. 3. If you are updating a wireless base station, use an Ethernet cable to connect your computer to your base station. 4. To run the update, double-click the MSBNDownload file. 5. Follow the instructions that appear on the screen to update the firmware of your device. While the firmware is being saved to your base station, the power light on the base station blinks and then turns orange. When the light is solid green, the update is completed. If the update fails, the power light continues to blink slowly until you successfully update the firmware. In this situation, you can try to update the firmware again, or you can reset the base station.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Computers & Internet Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
