Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I am using more oil and when i start the engine I get a puff of white smoke. It does run good though.
  • crocket104 Sep 08, 2010
    Yes, very much thank you!!
  • 43,501 Answers
The puff of white smoke is a good indication of the valve guides going bad... when off the oil seeps down and lays on top of the piston and then poof when you start it....also will use oil when running but not enough to make it smoke visibly....
eventually you will need to work on it, but no hrm in running it till then....
heatman101
Posted on Sep 08, 2010
Potiac fire bird starts hard.
Sorry but white smoke is a sign of water getting into 1 or more cylinders.I would pull the oil dipstick and see if it looks like a creamy color.If it does then you may have a blown head gasket or a crack in the engine block somewhere.
Oct 23, 2012 | 1998 Pontiac Firebird
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
White smoke heavy when started and then goes away...drives and after awhile rides alittle rough..Iwas told it might be something else besides head gaskets....
Depends on how much smoke. A little puff that goes away quickly is no cause for concern the flat six engine does get oil deposits under the piston skirt when parked and is considered normal.
Excessive smoke (fogging for mosquites) indicates a failed oil \ air separator. Confirm by removing the oil fill cap with the engine running - if the vacuum tries to **** your hand into the oil tube, your separator is a goner.
Not excessively difficult to replace yourself. The part is about $300 and you can replace it in a couple of hours, it is located at the rear of the engine, passenger side, top.
Mar 17, 2010 | 2000 Porsche Boxster
Engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Jun 05, 2009 | Garden
When I start my 1998 plymouth grand voyager I get 1 big puff of white smoke. What could the problem be?
It sounds like oil is seeping into the cylinders while the car is stationary and then being burnt off in one big puff of smoke when you start the engine. You're probably also burning oil when the car is running. You may notice that you have to constantly add oil to keep the level up. It's not uncommon for old engines to burn oil. The proper fix would involve either a ring job or a valve job both of which involve quite a bit of labor. If you had to pay a mechanic to fix it, it may cost more than the car is worth. It not a great solution from the air pollution standpoint but you could probably continue driving the car for years by just adding oil as needed. You may have to replace the spark plugs more often because the burning oil will tend to foul them.
May 11, 2009 | 1998 Plymouth Voyager
White smoke from the exhaust when I start the car
Hi!
What type of smoke can you see---
white smoke-
If you see a wispy, lingering white smoke that has a bittersweet smell, this is an indication that your car's engine coolant is leaking into the combustion chambers. This may be due to a leaky head gasket, or in a worst case scenario, a cracked cylinder head.
Make sure to take your car to the shop right away to get it fixed.
Thick white smoke---
If your vehicle is belching white smoke upon start-up, it is a sign that transmission fluid is entering the combustion chambers, possibly though a vacuum tube that connects the engine to the transmission.
This type of smoke can be confused with the normal puff of steam during start-up. If you are not sure, have your car inspected at the shop.
Blue/White Smoke--
A blue/white smoke is an indication that oil is being sucked into the combustion chambers through the valve guides. A quick fix for this problem is by replacing the valve seals. Valve seals are small, umbrella shaped pieces of rubber.
Do rate the solution.
Thanks
Rylee.
Feb 09, 2009 | BMW L7 Cars & Trucks
06 status white smoke uses oil vavles rattle on exceleration
Sounds like you blown head gasket,white smoke indicates steam,so there is water getting into engine,this is caused by blown head gasket or crack in cylinder head.
Dec 13, 2008 | 2006 Dodge Stratus
Engine smokes
There are only two things that cause smoke, one is oil,the other is coolant, coolant has a really nauseating smell, most likely the oil is your smoke, it is caused by worn valve guides and or leaking valve stem seals, if it doesn't use more than a quart every 1000 miles I would not worry about it, how many miles on the car?
Nov 01, 2008 | 1995 Volkswagen Jetta
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
143 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
