Question about Panasonic PT-47WXD63 47 in. Rear Projection Television
The blue lense is off by 2 inches and can't adjust it. The picture has a blue shadow.
  • Panasonic Master
  • 8,457 Answers
The tv have a problem known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have 3D pictures or colors shadows.The tv convergence board it dead.Require changing 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Sep 08, 2010
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
Older hitachi projection has heavy dark shadows, do I need a new lamp?
No,you might just need to Clean Mirror and Top of all 3 Tube Lenses, this Set does not have Lamp ,it has 3 Picture Tubes RED/Green/Blue. You might also need to adjust the screen drive Controls to each Tube.
Oct 05, 2010 | Hitachi 53UDX10B 53" Rear Projection...
The power went out and came back on, then the TV's blue lens was out of alignment with the other lenses . I reset the convergence but on the last adjustment with all the crosses the bottom blue crosses...
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks2.gif with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set. Keep in mind, I am not allowed to post MY email address here for you.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people.
Regards, SD TECH
Nov 01, 2009 | Panasonic PT-53TW53 53" Rear Projection...
We have a 47 inch Vizio, Blue shadows
my vizio made a popping noise and then screen went black. tv has power
Aug 30, 2009 | Televison & Video
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
I have a blue shadow outlining faces and pictures on my 50" is it color adjustment? how can I fix it - Please
No this is not a color adjustment sorry to say! it sounds like the circut board thet runs the color lenses inside your tv has some burnt out capciters and the circut board will need replaced! (the one thet controls the blue lens!) Please rate my response!
THANK YOIU!
Jan 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Panasonic PT-47WXD63 47 in. Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
