Question about Midland WR-100 Weather/RDS Radio
We have had severe weather all day and it didn't go off. It had been working perfectly for a year. When I turn on the weather/snooze button I get a constant loud squeal on every channel. any ideas??
The radio is defective. When the receiver fails, it defaults to a high pitch tone, alerting the user that the radio receiver has failed. It is not worth repairing the unit so buy a replacement. This was a common failure among the WR-100 units
Posted on Feb 01, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Check this website's FAQs page- http://www.crh.noaa.gov/lsx/?n=nwrfaq. Your answer may be in FAQ #10. It may be also that your local NWS transmitter may not have been receiving a good transmission because of the type of severe weather that you had. Maybe you should call your local NWS office and plea your case. I don't know if this will help, but this is my suggestion.
Posted on Sep 20, 2010
4 Suggested Answers
  • 12 Answers
SOURCE: My midland radio buzzes....no weather report when
Have you checked the seven (7) frequencies offered to find the best reception?
Posted on May 07, 2010
TOLhamRadio
  • 509 Answers
SOURCE: whenever I press the weather/snooze all I get is a
First, make sure you have a battery installed, and then run it off of the wall adapter. Extend the telescopic antenna all the way out. Go to MENU and then select the local channel for your county (channels 1-7 - use whatever channel is strongest). Once you select the correct channel, then hit the MENU button again, and then you should hear weather forecasts. Press the VOL UP or DOWN buttons to get the right volume for you. If you get to the 'CHANNEL' selection and still have a tone, then you have a defective radio that you will need to exchange. Good luck - let me know if you get it working okay. Happy New Year!
Posted on Dec 31, 2010
  • 11800 Answers
SOURCE: my midalnd weather radio WR-100
The high pitch sound is a sign of the autooscillation of the intermediate frequency amplifier from the tuner in your radio - hardware defect. The only way to fix that is to replace the tuner and realign it. This would cost you about $100 for the part and labor.
Since you can buy a brand new unit for less than $40 it's clear what you should do.
Posted on Jun 13, 2011
Midland Weather Radio Will not give a weather report
Have you gone into the setup mode and adjusted the voulme setting?
Just a thought. The volume may be turned down too low.
Mar 25, 2012 | Midland WR-100 Weather/RDS Radio
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
Jan 20, 2012 | Midland WR-100 Weather/RDS Radio
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Whenever I press the weather/snooze all I get is a constant tone, no voice
Dec 31, 2010 | Midland WR-100 Weather/RDS Radio
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
Our radio has never sounded an alert. It is programmed for Wabash County, Indiana, code 018169, and is plugged into an outlet. It has no batteries in it. Does it require batteries to work? The...
The answer to your first question is no, but the company that made this product and even I suggest that you put 3 AA batteries in the radio for back-up just in case you have a power outage. Maybe you had a power outage and that's why it didn't sound an alert. The possible answer to your second question is that it the storm itself may have not been severe enough for the NWS to issue a severe storm. You should check these websites for more information- http://www.crh.noaa.gov/lsx/?n=nwrfaq & http://www.weather.gov/nwr/nwrwarn.htm. FAQ #10 on the first website listed should give a clarification to you problem. They have certain criterias for issuing a warning and sounding an alert. The second website should give you a clarification on when the NWS sounds an alarm.
Aug 06, 2010 | Midland WR-100 Weather/RDS Radio
Settiongs for Weather Data World Clock
Citizen Weather Data Clock Settings.
To set time press and hold for 5sec "set" button
Use advance to add days, years, hours seconds.
Press SET to hold.
Oct 17, 2009 | Citizen Watches
I have the wrong day of the week, when I set the date.
The day of the week will be right after setting the year, month, and date. Adjust with step 2) from timekeeping mode (where time, date, and day can be toggled with button D).
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A --- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 27, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Manual
Hi, not sure why the manual I uploaded doesn't show up anywhere so here it is in 2 posts (too large for 1 post)
Stormtracker Vector Model: VEC438 Classified: UNOFFICIAL USE AT YOUR OWN RISK!
Programing Instructions
To Program Alert:
Turn the radio on and then press:
1. Menu button (may have to hold it a few seconds) and Alert should show in the Display.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the Menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the Menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the Menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the Memory button is pushed, the alert will not activiate.
To Program County
1. Menu button (may have to hold it a few seconds) and when ALERT appears, tap Menu button to scroll to County.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: All/Multiple/or Single
3. Then use the Menu button to select between All/Multiple/or Single (You'll need to know the S.A.M.E. codes for the area you want to listen to, otherwise select ALL and you will recieve "All" Statements, Watches & Warnings without having to select a specific County).
4. After making your selection, press the Memory button to the left of the Menu button if ALL was selected or Channel/Snooze button to the right of the Menu button if you chose Multiple or Single (You'll see CODE01 on the display) If you chose Multiple use the Menu button to choose which Code Position to enter (01-10) then press the Channel/Snooze button to the right of the Menu button. Enter the first digit of the S.A.M.E. code then press the Channel/Snooze button to the right of the Menu button to move to the next digit of the S.A.M.E. code. Repeat this for all digits of the S.A.M.E. code. Then press the Memory button to the left of the Menu button to lock in that code. Press the Menu button to select the next code position to enter. Then press the Channel/Snooze button to the right of the Menu button, then the Menu button to select the digit of the next S.A.M.E. code to be entered. Repeat these steps as necessary to enter in all the S.A.M.E. codes you wish to enter, each time pressing the Memory button to the left of the Menu to lock in each code position. When completed entering in all S.A.M.E. codes press the Memory key again to lock in all codes and return to normal operation. This completes the programming of the County Code function.
Example:
COUNTY SAME # NWR TRANSMITTER FREQ. CALL SIGN WATTS
Fulton 013121 Atlanta 162.550 KEC80 500
Colquitt 013071 Pelham 162.550 WXK53 1000
Colquitt 013071 Valdosta 162.500 WWH31 1000
NOAA Weather Radio Frequencies
162.400 MHz (WX2)
162.425 MHz (WX4)
162.450 MHz (WX5)
162.475 MHz (WX3)
162.500 MHz (WX6)
162.525 MHz (WX7)
162.550 MHz (WX1)
Channel numbers, e.g. (WX1, WX2) etc. have no special significance but are often designated this way in consumer equipment. Other channel numbering schemes are also prevalent. Best to just tune to the strongest sounding station in your area, this radio does not display frequiencies, only channel numbers.
NOAA Weather Broadcasts
Channel Frequency
1 162.550
2 162.400
3 162.475
4 162.425
5 162.450
6 162.500
7 162.525
A link to get the S.A.M.E. codes for your listening area: http://www.nws.noaa.gov/nwr/indexnw.htm
Aug 18, 2008 | Vector VEC438 AM/FM/Weather Radio
Midland WR-100 Weather/RDS Radio Logo
353 people viewed this question
Top Midland Audio Players & Recorders Experts
John
John
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
