Question about Maytag Dryers
Drum squeeks and make a noise when first turned on to dry
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 08, 2010
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Squeeking noise in rear of drum roller MDE9306AYA
the drum is riding on 2 weels on the back they usualy get bad after 4-5years also there is a seal around the drum that make it turn smuthly on the back wall, they need to be change.
it is like maintanance to your machine that should be done every 4-5 years and by the way check the belt also it might be dry by now
May 24, 2010 | Maytag Dryers
The dryer squeeks when the drying. I have turned the drum manually, and I don't hear the noise, it's only when it is turned on and turning that way.
the belt tensioner pulley has a roller with a bearing in it causing this squeak. greasing the bearing may help or a replacement will work even better
Mar 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Squeeking noise from drum when drying
Bit of a long shot, but I once had a machine with a crack at the root of one of the spokes on the big pulley wheel on the end of the drum - made a nasty noise once every turn as the belt tension came on and off that spoke. Good indicator of this would be if you can make the squeak happen when you turn the drum by hand, but this stops when you take the drive belt off. If the noise is still there with the belt off, try removing the hose that leads from the base of the drum to the pump and use the hole that leaves to try and find if anything (stray bra wire?) has got stuck between inner and fixed drums. Check for the same thing between the front edge of the drum and the back of the door seal. On some machines, you can also get a little access where the condenser plugs into the back of the drum. Finally, give the pulley wheel a good shoogle up/down, left/right and back & forth to check the bearings are OK (another long shot). A
Feb 20, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
29 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
