Question about Refrigerators
SubZero 532 model Water collecting in bottom of refrigerator below vegetable drawers
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
About once a month my subzero refrigerator drawer (700 series) gets a significant amount of condensation on the underside of the bottom drawer. its enough water that it is puddling on the floor below and...
the condensation is caused by fresh vegetables and uncovered food,and of course opening the door,now you cant do anything about opening the door but.....(i put a kitchen tissue under the drawer for this very reason and change it every 5 days.)
Sep 11, 2010 | Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
My refrigerator is collecting water under the vegetable drawers
The defrost water is supposed to go into a drain hole below the evaporation coils. The hole is clogged and the water goes down the back side of the refrigerator to the bottom. Seen it. You gotta clean out that drain hole. Shop vac works great.
Jun 12, 2010 | Kenmore Refrigerators
GE TBX18JA. Water is collecting below the
defrest freezer drain is in freezer. use hot water and a turkey baster untill water flows thru drain.
Jan 18, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water/liquid collects at bottom of refrigerator under vegetable drawers
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
Jul 08, 2009 | Kenmore Refrigerators
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
May 12, 2009 | Refrigerators
Refrigerators Logo
285 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
