Question about Element Electronics FLX-2610 26 in. LCD HDTV
Plugged a vga cable into it then it shut off never to turn on again. the red standby light stays on but nothing when i try the face buttons or the remote. any ideas?
This just happened to me. I unplugged the power cable from the set, plugged it back in, and it worked just fine.
Posted on Dec 19, 2010
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
My emerson TV will not even turn on. Took a nap with it on, woke up it was off. Everything else on the surge protector still works, tried plugging it into another outlet, but still nothing...
sounds like you blew the lcd or plasma, I did the same with my Vizio, hopefully you do not have the same problem.,, does the power light stay on and no picture, and if so try and turn the power button off, if it does not shut off, and you unplug it and it shuts off and the red light goes out, and then when turn it back on the red light is out until you turn it on and the same thing happens all over again
Jun 13, 2009 | Emerson LC320EM9 32 in. LCD HDTV
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
PS3 doesn't appear on screen. Possible power issue.
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Jul 27, 2008 | Sony Playstation 3 (PS3) Console
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
JVC KD-S70R
you have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Oct 25, 2006 | JVC KD-S580 CD Player
Element Electronics FLX-2610 26 in. LCD HDTV Logo
206 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
