Question about Hotpoint HSS25GFP Side by Side Refrigerator
Noisy side by side hot point. It has been keeping us up at night. Repair man says nothing wrong. It was not this loud when new three years ago. Any thoughts? Model # HSM25GFTA
  • Hotpoint Master
  • 43,501 Answers
Often the noise is the condenser fan underneath the frdge... the bearings get worn and then the fan starts to make a horrible racket...see if you can pin the noise down to that and then order a repalcement...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 08, 2010
Strange tapping noise
forget about using youtube try googling it and see if u can get help? not sure but the compressor has a seal that separates the coolant from the oil and when it goes or starts to leak u may get weird sounds? sorry cannot help more Ive heard clicking sounds before from the compressor but it was usually due to bad relay having to do with the starting process
Feb 19, 2015 | KitchenAid Refrigerators
Very noisy Liebherr CN4013-21 - 4 years old
Might be, the compressor is loose, now is it loose at base where it is fastened or the bearings are loose.
Dec 16, 2013 | Samsung RS2630WW Side by Side Refrigerator
Humming noise in house
Might be a noisy draft inducer motor. Try backing out the bolts and repositioning it is what I would try. Or pay a dude $400 for a new one.
Oct 30, 2013 | Dryers
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go out
Rod
US Parts Center
Jan 08, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
Dryer makes noise
Could be a couple problems. Hopefully simple like the belt getting worn, but if it's noisy that usually means the bearings are going on the drive motor. Check with the local repair man what it would cost for a new motor for the unit, but with the labour and parts you might be better off to pick up a new one.
Sep 06, 2012 | Crosley Norge Admiral Magic Dryer Roller
Noisy dishwasher
I have the same problem. I have been checking around on the internet, and it seems that the problems points to the bearing in the motor.
May 12, 2010 | GE 24 in. GLD5860LSS Stainless Still...
Steering wheel making loud noise
top bearing is noisy take the steering wheel off and oil then grease it
Apr 08, 2010 | 1995 Ford Taurus
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Side-By-Side Refrigerator Model GSS 23QSTA SS
Apparently the digital read out sensor is bad. 45°F is to high for safe food storage. The fact that the milk spoils is another factor which speaks on its own that there is a temperature control problem. There is no "defroster fan". There are two fans in the unit. One is the air circulation fan located inside the freezer compartment and the other is the condenser fan for cooling the refrigeration system. If you had called for service in the first year it would be covered by warranty with the exception of the service call charge. After the first year ends electrical and control problems are not covered. If the evaporator fan in the freezer is noisy there is something wrong with it. It could be the source of your whole problem.
Mar 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge making loud snapping noises
we have much the same problem except ours was going on for some hours at a time and then off for short periods. contacted Comet engineer who says its the compressor and will cost almost as much as a new machine to fix it. we are disgusted as its only just over a year old and has been repaired twice already. we would also add that both
the fridge and freezer are now completely out of action and have been all over the Easter period which has caused us much inconvenience. we will take this matter further if no satisfaction is gained from Comet.
Feb 28, 2008 | Admiral 26 cu. ft. Side-By-Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
127 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
