Question about Amana Heating & Cooling
Unit is icing up when i got their blower was runnig rest it and run good cap is good motor is good unit is about 8 yrs. old
Could be a number of things. To start, check air flow across the coil. Is coil dirty? Is return air blocked. Once you have determined airflow across evap coil is good. Check the charge.
Posted on Sep 08, 2010
FA4B blower assembly noise
It is possible that the actual fins have separated from the hub. Hold the shaft of the motor (as to stop it from spinning) and the try to spin the fins. You then may notice the welds are broken. Could just be a bad motor, could be just the wheel. Good Luck!!
Aug 31, 2017 | Carrier Heating & Cooling
Rheem rgph 10eamer 8 yrs old ...blower motor wont stop running...i had the a/c on....decided to ck the furnace ...switched to heat...blower still running....no spark from direct spark...
Hi Richard. The switch they are talking about has a small tube coming from the induction blower housing straight to the switch. The best way to test it is to blow and **** on the tube while it is still connected to the switch. You should hear small clicking sounds coming from the switch, if not than it needs to be replaced. Another thing to try is a small wire or paperclip through the small opening where the tube came off. Sometimes this gets clogged and causes the same issue. Other than that, it can be a blocked flue or the inductive blower motor itself is not working properly. Hope this helps and good luck!
Sep 26, 2010 | Heating & Cooling
Hi, I have Lennox gas furnace Model G12Q3E-82 (about 30 yrs. old). When running the A/C, I noticed there was water leaking or dampness around the bottom of the furnace. I removed the hose from the drain...
Hello TRC Oh boy your motor got wet!Time is needed to let it dry out.You could try a 7 1/2uf/370v run cap to help speed & reduce dry time.The more the motor runs the more complety it will dry. If the motor behavior doesn't improve in a couple of days or you smell anything burning at all you must replace the motor.Rember the coil on top of the furnace will freeze/ice up if out side unit runs during NO blower operation.It will defrost quickly when the blower is working.
Jul 23, 2010 | Heating & Cooling
I have a stihl br340 backpack blower that stalls
pull fuel intake line and blow through it to see if filter in tank is clogged, also the vent in fuel cap may be blocked up, try runnig it with fuel cap loose to check for this, if this doesn't help, prob gonna have to tear in to carb
Apr 21, 2010 | Garden
Blown Heater blower motor
you will have to replace the brain unit its shorted out
Jan 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Goodman furnace app 6 yrs old blower only runs app 4 minutes then kicks off does this continuously
You need to remove the blower ,blow it out with a good air compressor. oil if if there is a place. be sure to blow it out once a year. its thermo protected. To stop from burning up the motor.
Aug 17, 2009 | Heating & Cooling
The coils behind the stainless back panel are caked with ice. I have defrosted them...now what.Fridge won't stay cold and ice keeps building up.Unit is 17 yrs. old. traulsen freezer/glass door fridge ERS...
may be you have problem with the Evaporator fan motor not running, defrost heater, defrost timer, open gap on door gasket and bad thermostat (cold control), it may kept the compressor constantly running. Good luck.
Jun 27, 2009 | Traulsen Refrigerators
I have a Ruud 90% furnace (18 yrs.old) Several days ago, I had a complete ice-over of the evaporator coil. Filters are clean, and airflow unrestricted. After defrosting coil (48 hrs.) while testing, I note...
The motor shutting off after 30-45 seconds means it is probably getting hot and shutting off on thermo overload safety in motor. Two things can cause this: #1 is the motor is defective. #2 the run capacitor has gone bad. If you want to try and save money replace the run capacitor 1st and try it. If that doesn't work replace the motor. You would replace the run capacitor at same time anyway.
Jun 23, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
