Question about Garden
What brand and wt. oil to put in my unit - Garden
  • 10,865 Answers
Hello. Take your saw to a local saw shop. They will have the oil that you need and the expertise to be sure you get the right products. Next time please enter your brand name and model so we can be more helpful to you. thanks. J.
Posted on Sep 08, 2010
What type of oil does a Nissan turbo diesel Engine 2.5L 2oo6 model take.
Any brand of 30 wt engine oil will do. Rotella 30 wt is a good brand.
Dec 06, 2016 | Nissan Cars & Trucks
Type oil for 6.75 hp 149c toro lawn mower?
30 wt. automotive engine oil. The same as you put in your car only use straight 30 wt. not a multigrade 10 w 20 .
Mar 16, 2016 | Toro Garden
Howmuch,and what type of oil?
Use McCulloch two stroke oil in the fuel....Do not use outboard motor two stroke oil. (I personally use Stihl at a 50:1 ratio in every one of my saws regardless of brand.) Use any brand of bar oil for the guide bar. I also use 30 wt motor oil though it is NOT recommended and know that the life of the guide bar, sprockets and chains are shortened.
Sep 25, 2014 | McCulloch Garden
Front shocks are vary soft. drained and filled to spec
If the dampening action is still to soft for you, you'll have to drain the forks again and this time put a heavier weight oil in them. If you put 20 wt. oil in last time, try 30 wt. this time. Always use a good quality "fork oil" never just plain engine oil.
steve
Aug 03, 2011 | 2003 Harley Davidson FXSTD Softail Deuce
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Honda 2500 PSI Gas Pressure Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
I have a gen power gx400i generator 4.0kvaor 3.0kw, 4stoke single cylinder air cooled.I'm not sure what type of oil is needed?
Hi and welcome to FixYa, I am Kelly. Oil changes are supposed to be every 100 hours. You should use SAE 30 WT (non detergent) oil for at least 3 oil changes / 300 hours then 1 cycle of HD-30 WT oil as it does a bang up job of cleaning things out of the crank case and prevention of the oil rings from sticking on the piston skirt. I have made this recommendation for at least 30 years and never had to rebuild a home owner or RV type engine in a unit where it was known the owner did this cycle of oil changes in a generator. (Vavle work yes.. engine bearing and piston rings no!) .. The brand does NOT matter as long as it is SAE 30 WT oil. Lubricants can not get the SAE rating if they do not meet the standards. Just do NOT use a synthetic oil in it.
Kelly
Nov 29, 2010 | Coleman Powermate Premium Plus 6250W...
WHAT TYPE OIL GOES IN THE LOWER END? ON THE RIGHT HAND SIDE OF MOTOR LOOKING DOWN THERE IS A BLACK OIL CAP. WHAT OI DO I PUT THERE?
If you are talking about the transmission oil , 10w-40 JASO MA motorcycle oil will work. Most racers will use either an 80 wt (weight) motorcycle gear oil or for the racers edge a 70 wt motorcycle gear oil to increase the life of the aluminum plates in the clutch and help preserve the transmission gears.
Oct 01, 2010 | 2004 Honda CR 125 R
What brand motor oil is the best for 1998 buick century custom
Any major brand will do 5w30 or 10w30 wt. plus a delco filter. Do not use fram.
May 12, 2010 | 1998 Buick Century
What kind of oil do I need to get for my 1987 Porsche 944 Turbo
Valvoline Racing 30 wt. no it should not burn oil ; do a compression test
Apr 28, 2009 | 1987 Porsche 944
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
