Question about Whirlpool LSR5132PQ Top Load Washer
The machine overflow and didnot stop waterflowing to the setting
  • Whirlpool Master
  • 8,220 Answers
My defy laundromaid 720 does not stop the waterflow once the drum is full, which leads to water running out the bottom of the machine and then gives me an error LE
problem either in the water level control switch or the solenoid valve that shuts off the water
if the water doesn't shut off but it progresses progress to wash while still filling, it will be the water solenoid valve
Oct 08, 2016 | Washing Machines
Why does it overflow?
Check FAQs in your user manual. Failing that go to manufacturer's website and check what's there.
May 16, 2015 | Washing Machines
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
Washing machine overflows
Make sure that your load selector is in the lowest setting for the water level
Jan 08, 2014 | Washing Machines
Water dripping not running when making coffee
First question:Are the rest of the machine still working correctly?
Second question:How was the waterflow before descalling?
Here are short description on how most of these machines work.
It will have a cold water reservoir for filling with cold water with some sort of water full sensor, it will then be followed with a high pressure pump.which are used to fill the boiler.After the boiler it will then go out to your to disspencers.in your case the steamer and one for coffee.The outlet at the boiler will propably be split in two by using valves.
To come back to your problem i assume it had a waterflow probleme before you descalled.When you are descaling your machine their are some times pieces of scale that is not propably disolved by the descaling process which will get stuck in the pipe work acting as a valve
causing waterflow problemes.
The other probleme might be that your water dispencers valve might be faulty either by a poor supply(power) or the sollenoid is starting to size up.
Just switch of the machine when taking of any covers you are working with water and electricity which do not mix well
Mar 26, 2012 | Gaggia Baby Espresso Machine
Water will not stop filling up the washer after the rinse cycle and it overflows into the floor.
Does it shut off the water if you turn off the washer? if so then it may be the water level pressure switch. I've only seen one go bad in all my years but it can happen. There is a tube that runs from the side of the drum to a cylindral style switch located behind the control panel. as the water rises the pressure does as well. thats how it senses the level. Either the tube is being blocked by foreign matter or the tube may have a hole in it or it may have come off. Check this first. if everything appears ok then you may have a bad pressure switch. I normally hook a (CLEAN) tube to it and blow into it. You should hear a click then the solinoid shits off the water. That's How I check 'em. Lastly, if the water does not shut off when you turn off the washer, foreign materal may have gotten in the water inlet valve and is not allowing the solinoid to close to stop the waterflow. If this is the case, try disconnecting the hoses and cleaning the inlet valve. In most cases it should be replaced.
Oct 15, 2009 | Kenmore 22422 Top Load Washer
The belt broke, it was replaced, but afterwards its overflows,
If water is overflowing check the small plastic line going from the bottom of the tank to the water level switch. It could be disconected. To check the water vales, set machine to fill, while the water is running into the tub unplug the power cord from the wall, the water should stop, if not the water valve is faulty.
Oct 11, 2009 | Speed Queen Washing Machines
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
The cleaning cycle is not complete (Jura F9)
This indicates that the Flowmeter is either dirty or defective, it sends incorrect messages back to the electroninc board about the waterflow. It`s located on the left side (seen from behind) as a white sircular box with 2 hoses and an electrical contact on top of the lid.
May 16, 2009 | Jura Capresso Impressa F9 Espresso Machine
Waterflow
If the unit was installed with a saddle valve, which is most often the case, you could try turning down the water pressure by tightening the valve a bit. Just follow the copper water line from the humidifier back to the main water line and look for a little valve that you can turn. Try to tighten this enough so that you still have water flowing, but at the proper volume so that it doesn't overflow and splash all over.
Dec 16, 2008 | Aprilaire 600 Humidifier
Whirlpool LSR5132PQ Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
