Question about Stage Shock Sensor AS94954P
Doors keep locking back whenever you unlock it and also after you shut off alarm it will go off even after you open the doors
  • 120 Answers
Its possible to have a stuck button which could cause this.
Posted on Sep 08, 2010
Having issues with auto door locks, windows and side mirrors
Possible body control unit is faulty or broken wire or the unit is wet need to get it checked diagnostically to see what's going on
Jan 24, 2015 | Cars & Trucks
Why does my alarm keep going off on my 2000 Ford Explorer when I unlock the doors?
check the battery in the keychain. or replace. Make sure the keychain remote doesnt get wet!
Jun 03, 2012 | 2000 Ford Explorer
My alarm cycles on and off on when vehicle is shut off.
  • Often times when this happens this is a problem with your door switch. The doors being locked or not does not necessarily mean that the alarm is not armed. When the door switch begins to fail the alarm senses the door being opened even if it is closed because the switch is sending a signal that the door is open. You could just need to reprogram the FOB as well.
  • Unfortunately the FOB must be programmed at the dealer or a technician with a proper interface. You might be able to ask the dealer to test your FOB first.
  • The switch you will notice on the inside of the drivers door and is activated by opening and closing of the door. You can pop that switch out and look at the wiring and give it a little cleaning and see if that helps. If it does it will be temporary and the switch will need replaced.
  • Hope this helps.
Nov 16, 2011 | 2006 Chrysler 300
My factory alarm keeps going off on my 2005 Dodge Stratus SXT when I open the door with my key. The only way I can turn the alarm off is by unlocking the door from the inside.
I hope you solved your problem and this is a late answer so if it helps anyone then OK good. When the door is open look down on the inside trim where your door meets when it shuts. There is a rubber boot covering an activator switch. Simply remove the screw, pull the module out and unplug it. Whenever you open the door it will not activate the alarm. There is nothing in the door that activates the alarm; only when you open the door.
Sep 23, 2011 | Dodge Stratus Cars & Trucks
Whenever i unlock my camry manualy ( key in the door ) the alarm goes off. Also if i open the back door before the front door the alarm goes off. I have to use the remote key or i cant get into my car and...
this is due to a bad switch in the drivers door, when you use the key to unlock the door it should shut down alarm, also the alarm module may be going bad, the alarm is setting itself on, when ever you lock the door the alarm turns on, you will need to replace the switch on the drivers door or unlock the passenger side door that also has a switch that disarms it, the switch is on the lock itself, thats the problem you are having , good day,
Apr 15, 2011 | 1997 Toyota Camry
Bought from dealer with no keyless entry. alarm activates when doors are locked with power doorlock system. alarm sounds when we open the door. how do we de-activate the alarm before unlocking the door?
Opening the drivers door with the key is supposed to shut down the factory security but the drivers key cylinder usually goes bad. You will have to unlock the rear tail gate lock cylinder with the key and that will shut down the factory security, before opening the drivers door.Your other option is to have an aftermarket keyless entry system installed, which will open the doors remotely while shut down the factory security at the same time.
Jan 25, 2011 | 1996 Jeep Grand Cherokee
Used the key to unlock door and alarm started going off. put key in ignition to start, but wouldn't. removed battery cable, do to neighbors, and the alarm keeps sounding. how can I shut it off? just...
With the drivers window down, and the doors closed. and locked connect the battery and lock and unlock the tailgate with the key, you need to unlock it twice to unlock the doors and turn off the alarm. If the locks are working like thier supposed to the drivers door will be unlocked and opening it won't set off the alarm. the truck should be back to normal. If not disconnect the battery again. Drivers window down. Put the key in the switch and turn the key on to the run position. With all the doors closed connect the battery. connect it good and don't bounce it around. If the battery casbles aren't clean clean them good so it'll connect good. If it still is alarming then the doors switches are likly. Or the door locking motors. You should be able to lock all the doors ( including the hatch) by hand and get the system to reset. Try it all again using a different door to double unlock as a lock switch might be sticking. If the system can't verify that all the doors are closed and locked it won't reset. If you connect the battery wihg the key turned on the system thinks it's already running and appeares to be in the unset mode.
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Jeep alarm will not turn off
The ignition security on/off is located at the trunk lock. unlock and lock rear gate and the alarm will turn off. My jeep sat in my drive for a month before a jeep tech told me this. It still triggers the security sometimes when I unlock the passenger door with the key and I go straight to the rear gate lock and it shuts off instantly.
Jun 27, 2008 | 1994 Jeep Grand Cherokee
Stage Shock Sensor  AS94954P Logo
52 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
