Question about Kicker Car Audio & Video
My kicker 350.1 car amplifier playes great when volume is low but when I turn volume up to 24 or more my mids and highs start acting like the amp is turning on and off but when I turn it back down past 20 it will work like nothings wrong with it
4 Suggested Answers
blackberries
  • 80 Answers
SOURCE: I need to know what mid speaker is good for my 4
mainly less battery draining/power consuming! specs seem to be the same
Posted on Feb 27, 2009
  • 17 Answers
SOURCE: powers down at high volumes
If your head unit powers off at high output it could be several things.
1. check ALL your grounds (head unit, amp, etc..)
2. it could be a a short.
3. head unit could be defective
disconnect the amp power/signal and see what hapepens.
If it doesnt happen you probably have an open ground or short in your amp power or signal cables. Amp could be defective but that is unlikely
If it still dies when the amp is disconnected it is isolated to your head unit. Check your head unit's ground/power/fusing or swap in another head unit to eliminate wiring faults.
Good Luck!
Posted on May 01, 2009
  • 11 Answers
SOURCE: I have Kicker ZX 650 4 channel amplifier and 4 DB
As far as I am aware you need to get 2 ohm speakers. I run a 4 ohm subwear as the Alpine Type R sub is 2 ohms. I'm not 100% on this though but you may get around it by bridging your speakers by connecting both speakers to the amp as normal but swapping the speakers negatives around! That may cause the amp to run as if only at 2 ohms. Hope this helped!
Posted on Dec 06, 2009
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
Sub not working
there might be transistors that went bad
May 01, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Kenwood ps 150
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage is not dropping too low, you may have a defective speaker or a short in the wiring. Check the resistance of each individual voice coil to make sure all are near the rated impedance.
Dec 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Car Audio & Video Logo
140 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
