Motor is working but cylinder is not moving - Washing Machines
    Novelist:
    Champion:
  • 220 Answers
Sounds like your belt may be broken. Now sure what model you have, but you should be able to gain access thru a panel, either on the front of back. Make sure you unplug it when you operate on it. Belts are fairly cheap and easy to put on.
Posted on Sep 08, 2010
What is causing the rear wheel to lock when in gear?
well i would say it had dropped a valve on one of the cylinders,its very hard to say which one but usually if it did it at speed it will have made a bit of a mess in the head.Take each of the spark plugs out and have a look in the spark plug hole on each cylinder with.a small powerful torch and look for bent metal or metal fragments.usually on a v twin its the rear cylinder that suffers as it runs hotter but its not always the way.
Dec 07, 2015 | kawasaki VN 800 Vulcan Classic Motorcycles
My 22 ton Huskee log splitter hydraulics quit working, I checked the fluid, that is fine, what next?
Its only a guess but see if its sheared the drive key between the motor and pump.
Dec 27, 2014 | Heavy Machinery
My convertible top on my mustang gt wont go up or down
Check to see if the top motor is running when you press the top up switch. Car has to be in park with emergency brake engaged. If motor runs but top will not move or binds then one or both of the lift cylinders are bad. Usually there will be hydraulic fluid leaking from the cylinders if one or both will not hold pressure. Replace cylinders if bad. The top could probably be manually closed if the lift cylinder arms are detached from the top frame.
If motor does not run when the switch is pressed then check your fuses, the switch and the connector at the top motor to see if it is getting power.
Jul 15, 2012 | 1991 Ford Mustang
1990 camry shifting cable went out
your clutch has went out or the slave cylinder to clutch or clutch master cylinder ck master for fluid if low fill and work clutch peddle to pump up slave cylinder if master is full ck at trans to see if slave cylinder is moving if moving clutch in most likely bad and needs replaced.
Jul 15, 2012 | 1990 Toyota Camry
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
Nov 06, 2011 | 1998 Honda Civic
1998 Mercedes Convertible Top Slow and Drips Oil
Your top is moved by an electric motor wich operates a hydraulic pump which moves two pistons which move the top.
The "oil" thet you see is probably hydraulic fluid leaking from the drain hole in the car near the tire.
You have a leak in the hydraulic system.
You need to start at the motor/pump/reservoir unit behind the seat and find the leak.
Most commonly, it is a bad line. Second in popularity is a bad cylinder(s). Third on the list is the motor/pump/reservoir.
If you replace a line, do them all. If you replace a cylinder, replace them both.
Karl at topgunwon.com
Aug 13, 2009 | 1998 Mercedes-Benz SLK
Boat motor won't turn off !
im not sure on your motor but if you have a choke tube with a cylinder in it the cylinder could have came out take the top off and hit your choke and see what moves
May 16, 2009 | Boating
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
