Question about Whirlpool Dishwashers
My dishes and silverware have a dry film on them, possibly water deposits. The food is off but the glasses and silverware look bad and don't look clean with this residue on them. Washer is 9 years old
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
Daniel
Jan 07, 2011 | Kenmore Dishwashers
Film left on glasses. doesn't seem to clean any dishes very well, expecially silverware.
Two other possible causes are a high mineral content in the water, or depending on the silverware, they maybe getting etched.
Use a Rince Aid to eliminate this problem. Don't use powder or old dishwasher soap.
Nov 24, 2010 | Dishwashers
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
The dishes do not get clean. Food is left on plates, in bowls, on silverware. Coffee stains are building in cups. Milk leaves a "film" on glasses. When the cycle is finished, it appears that the water...
Hi, it sounds like your dishwasher is plugged up with soap deposits, and/or Calcium deposits.
In an empty dishwasher, put 2 cereal/soup bowls full of vinegar on bottom shelf, and run your dishwasher.
This should clean out all the deposits.
I do this about once every six weeks as our water is very hard.
Fred
Sep 30, 2009 | Dishwashers
Dishes, glasses & silverware have white film, look unclean!
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
May 11, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
I have a GE, PDW8600 Series, problem is - no matter how I arrange dishes the top rack always has deposits left on dishes that are on the top rack. The water is plenty hot.
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions.
If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. For more, see "Dishwasher Doesn't Wash Well."
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra-hot settings, such as "Power Scrub," and use the "Energy Saver" dry cycle.
2) Adjust detergent amount.
3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
More about dishwasher problems & repairs:
Apr 20, 2009 | GE Profile PDW8600J Built-in Dishwasher
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Dishwashers Logo
77 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
