Question about HP Compaq Presario CQ50-130US Notebook
It will not come on once you push the button. It is plugged in.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
1990 hd flstf when I push the start button it will fire both plugs once, with button still pushed there is no fire, let off start button & it will fire the plugs again. whats wrong
The ballast resistor is open or the wiring to the resistor. The ignition switch can be bad in the start position but be ok in the run position.
Mar 13, 2017 | Tablets & eReaders
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
I have a noma outdoor timer N1506 I lost the instructions how to program it could you email me telling me how it is done thanks JIm
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1- Plug in the timer.
2- Set the time of the day (on the hour, example. 2. Pm) using the top TIME button. For pm there will be a dot to the lower right of the 6.
3- Once the time is set push the MODE button, this will replace the 6pm with a flashing P.
4- Push the TIME button again to set the time you want the timer to come on. (Remember for 6pm there will be a dot to the lower right of the 6.
5- Push the MODE button once the desired time is set, an E will appear.
6- Push the TIME button again to select the time you want the timer to go off (example 10.pm).
7- Push the MODE Button again. The time of day 2. (Pm) will be displayed. If the timer loses power just repeat the above steps.
Dec 04, 2009 | Kitchen Appliances - Others
Roxy 70's watch alarm goes off every hour. I
This manual will help http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
I think these are the directions you need 2.0 Alarm and Chime On/Off 2.1 In Normal Display hold B-Button,and push A-Button once: Chime will be on. 2.2 push A-Button once again: Alarm will be on 2.3 push A-Button once again: Chime will be off 2.4 push A-Button once again: Alarm will be off 2.5 Release B-Button, the Display changes to Normal Display immediately.
Jul 13, 2009 | Watches
Hi, I need help with this brand of Roxy blue Calculator watch insurction and I got them from ebay but she dont have any booklet. I try to set the time. I can't do it so would you make simple explain to me...
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf if you change the following: C=C Mode A=Select B=Advance
Normal Time Setting 5.1 In Normal Display, hold C-Button for more three seconds and then push C-Button once. Tuesday flag and seconds digits will flash. Push B-Button once to reset the second to zero. 5.2 Push of A-Button once: Minute digits flash and advance by depression of B-Button 5.3 Push of A-Button once again: Hour digits flash and advance as above. 5.4 Push of A-Button once again: Month, digits flash and advance as above 5.5 Push of A-Button once again: Date digits flash and advance as above 5.6 Push of A-Button once again: Flag of weekday flash and advance as above 5.7 If push of C-Button during any changing time, Normal Display will be appeared
Jun 14, 2009 | Watches
Stuck on forgien languages.
push menu button once
push > button 4 times
push > button 3 times
push menu button once (now you are in the language selection screen)
push > button untill english is chosen
push menu button
now push far left button (has a monitor pic on it
Now you are back in english enjoy
bcmalloy
Apr 29, 2009 | ASUS VW222U Monitor
Second remote will not recognize the wii mario kart. Second remote will work with all other wii games, except for Mario Kart.
Had the same problem last night.... Turn off the wii system by unplugging , wait a couple of seconds and plug back in. Next, the front of the wii has a pocket that opens, there is a red button. Put the disc to mario kart in the wii once you see the federal regs push and hold the red button on the wii for 15 seconds then once this 15 seconds is up with the controllers battery case open push the red button to the original controller. All of lights will flash and then stop. Push the red button on the wii console again just once. Then push the red button on the second remote wait till all lights stop flashing push the red button on the console and now they should be married to the wii system. Hope this helps----do you know how to get the volume? We don't have any volume
Jan 24, 2009 | Nintendo Mario Kart (Wii) for Wii
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
May 17, 2007 | West Bend 85146 6-Quart
HP Compaq Presario CQ50-130US Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
