Question about Mitsubishi WS-55513 55" Rear Projection HDTV
I have a Misubishi WS-55513 55 in. Rear Projection HDTV Television.. I replaced the capacitors last month on the DM board and it worked perfectly. Now the tv turns on but the picture is black and there are colored stripes running up and down the right side of the screen. The sound is perfect and I can see the channels shown on the tv. Any ideas?
  • 505 Answers
Probably need to check those connections to the dm board, hopefully one is somewhat loose. reseat all those and hopefully the prob will be solved. you can also reseat the doubler board (it sits in the shield upright in the middle of the signal board, just to the right of the dm board) ... all the pic is processed by that doubler board. let me know if I can be of further assistance.
Posted on Sep 09, 2010
I replaced the 4 capacitors on the DM board and got about 6 months out of my Mistubishi WS-55613 projection television. Now it is doing the same thing again with the blinking green light and no power. I...
For their cost it's probably worth trying to replace the capacitors again.
If there's space around the capacitors then I suggest you get high voltage rating i.e if the existing ones are 16V then get 25V.
Also worth checking for any other damaged components or scorch marks on the PCB.
Jun 17, 2011 | Mitsubishi WS-55613 55" Rear Projection...
We have a mitsubishi diamond television the timer keeps turning off and now the television wont turn on at all
hi,
Your tv have problem with Digital module DM board. there seven filter capacitors (1000uf 16V ) in the DM board. if any one of it is faulty the this problem can occur. its a regular complaint for this model. just replace the capacitor. i have added the picture of the DM board you have to replace the marked capacitors . Also check the two fuses in the same board 4Amps fuse and 2Amps fuse.
ok
Jun 08, 2011 | Mitsubishi WS-65909 65" Rear Projection...
Describe your Mitsubishi WS-55711 65 in. Rear Projection Television Problem. It has a bad dm board is there any way i can get it fixed?
How did you determine it has a failed DM board? What are the symptoms the tv is having? The DM board usually needs the capacitors replaced.
Feb 19, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Have a misubishi ws55859 green light blinks will not turn on it all started when the tv was unpluged
The dm board power circuit has gone bad and would require many capacitors to be changed. This board is a box (metal grey) on the left extreme as viewed from rear next to input connector board. It is not recommended as an abinitio DIY Project. Caps faults are difficult to find and require an ESR meter. Call for professional help and should cost 180 to 220. Check it out at www.fixurtvs.com for more questions and price quotes.
Feb 26, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws65511 green blinking light had power failure last nite power came o briefely then off when power was fully restored the green blinking lite appeared have tried numerous things HELP
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v.
Jun 24, 2009 | Mitsubishi WS-65513 65" Rear Projection...
WS-73909 Blink of Death Question
these capacitors are not dangerous but, be sure you install them exactly as you removed them for, if they are installed backward you have a firecracker when you power them up
May 22, 2009 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi ws 65857 powers off
Your set is the V17 chassis it doesnt have a DM board, your problem is most likely centerd on the main Circuit board .
Jul 24, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
846 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
