Question about Ryobi Garden
Lookling for 230mm Ryobi precision 2 wheel bandsaw blade. And we need a bench top for a Triton RTA 300 router table. what is the cost and how do we get these? And where from? we are a community based access program for disability clients, and do woodwork/toymaking for charity.
  • morry_ecc Sep 10, 2010
    thank you for your prompt reply to my request
  • 10,865 Answers
Hello. this is the source i use. http://www.bandsawbladesdirect.com/?gclid=COK74Izm9qMCFZJ95QodrCBt3w
the cost is usually under ten dollars.
For the router table you might check out this site. good stuff and fair prices http://www.carbatec.com.au/machinery...p-router-table
Posted on Sep 08, 2010
Blade moves to the front and then pops off
1. Make sure you put the right tension. Check tension recommendations on your bandsaw/ manual.
Here's a good article about that. What is Bandsaw Blade Tensioning and Why is it Important
2. Adjust the blade tracking. I suggest you to read this blog for reference. Band Saw Tracking Procedures
Jul 01, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
Looking for a 11"sychronizing belt from a 9" 2 speed band saw from another bandsaw fit a bandsaw of another make
Try to find a local auto shop. They might a have a belt available for your bandsaw. If you need band saw blade, I suggest you visit sawblade.com .
Apr 26, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
Can you use a 59 1/2 in. blade on a 9in ryobi bandsaw.
I think 59 1/2 inch blade will still fit on your bench top band saw. But try to give a call you supplier for assistance .
Dec 20, 2012 | Ryobi 9 in. Benchtop Band Saw
I have been given an older bench top bandsaw make is Brico model BS 360 wouls like to know where I can get a copy of the manual for this and the blade length it requires. Thanks for the help
It takes a 70 inch blade. Don't go any wider than 3/8 inch, a 1/4 in blade works well. Get as thin a blade as possible. The 6" wheels can be ******* blades. I had new tires made for mine but have lost the name and address of the source so now I am on a search for those!
You will probably have to get the blades custom made. I get mine made at Island Saw in Victoria BC Canada. Not too expensive.
Apr 04, 2011 | Saws
I'm looking for a table top band saw that will cut 4140 and harder steel, what kind of blade and saw would you recommend. ?
i have a great company for you to contact to find the perfect blade for your needs. go to www.doall.com and click on the doall sawing tab and find the customer support phone number. call them during business hours and you can get at blade tech on the phone that will ask you a few questions to what saw you have and what your cutting and they can put you on the perfect blade. i use them for a bandsaw we use at work, we manufacture awnings and signs. i get all my bandsaw blades from Doall
Dec 24, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
7. close the covers
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
I cannot get the blade to track correctly on my JET 12" band saw. What could be wrong? I have done exactly what the manual says to do. I am not sure the square box on the outside is fitting. The little arm...
i love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for bette adjustment and protect teeth on the band.
start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock it in.
4. repeat previous operation on external guide block and after you slide paper out, lock it in position.
7. close the covers
8. adjust hight of the guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
this general rule applies to all bandsaw, regardless of brand, make, vintage. do remember that this is not a toy, it will cut through, wood, metal and your fingers...
do remember, that these operations must be performed every time when you change the blade, to not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, use protection screen and googles, you have only two eyes and there are no spares...
Jul 30, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
Cut is always crooked. From the top to the bottom of the cut is always crooked. Can not get the saw to cut a 90 degree ( or even close to 90) angle. Even of I adjust the table to be out of square to the...
It sounds as though you may be cutting too quickly. Try decreasing the pressure you are applying to the wood.
You could also try tightening the blade more, until it PINGS when you flick it with your finger.(When it's stationary of course)
I'm assuming your guides are adjusted correctly.
JR
Sep 27, 2009 | Ryobi 9 in. Benchtop Band Saw
Garden Logo
63 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
