Question about Goodman CKL42AR42 Air Conditioner
Hello, my HVAC is constantly freezing, even after freon is added. I was told that I have a leak in the coils and need to chance the air handler - the outside unit is about 10 years old - air handler about 18 years old. I would like to get only the air handler for my R22 outside condensing unit. My question is if in the future can I use this same 3.5 ton air handler with a new 410 condensing unit once my outside unit needs to be replaced. In other words can a Goodman air handler be used first with an R22 condensing unit and later with a 410. Also is this OK with the warranty? Would appreciate if you could confirm ASAP
I'm new at this and I can't tell how old the post is but I'll contribute anyway.
You probably have fixed the problem by now. I wonder what part of the system is freezing up. I don't have a lot of experience but I know you can get frost where there is a restriction in the freon. If the freon line filter near the outside unit has frost on the house side the filter is partially plugged. I have also seen fost on the evaporator (attic "A" coil) when there is a shortage of return air flow. You could have a plugged filter or colapsed return duct, or even an "A" coil with a lot of dust covering and plugging the fins. I guess restrictions in your room air supply registers could cause the problem too. Maybe you have most of the vents closed off to save energy. Just some possibilities.
Posted on Oct 31, 2012
  • Goodman Master
  • 43,501 Answers
No you can not use a R-410 air handler with a R-22 condenser unit...the exspansion devices are different as the properties of the refrigerants are enough different that they are not interchangable...
Really your only choice is to replace the whole unit as it sounds like the exspansion valve or the orfice is partially clogged and it makes you constantly freeze up....
There are some things you could do to make it work at reduced capacity but it is way beyond what I could tell you through a computer...
heatman101
Posted on Sep 08, 2010
We have a 1997 Coleman pop up camper. We are having issues with AC. It blows out some cold air but not a lot and it keeps leaking water on the inside of the camper. I have called a repair man they said...
If you have some cooling, but not enough, then chances are that the system is low on freon. The only reason a system would need freon is because the freon leaked out. If the leak is not sealed before recharging with freon, the freon will eventually leak out again. Leak repairs are expensive so if it's a small leak it may be more cost effective to recharge the system every two or three years. Freon recharging is not a do-it-yourself job. Only people certified to handle refrigerant (freon) are allowed to recharge an air conditioning system. OR 1. Extremely dirty air filter restricting the airflow through the inside unit. 2. Extremely dirty (clogged) cooling coil restricting airflow AND IF IT IS LEAKING If you do not see ice build-up on the larger copper tubing (covered with a black, sponge insulation) when you run your system, then you probably have a clogged drain line. A clogged drain line is usually caused by algae build-up inside the drain line. And yes, there is something you can do to prevent this condition. Algae is a living plant and will grow in your drain line until it clogs the line. The air handler provides a cool, damp environment for development of molds and mildew and if left untreated these growths can spread into your ductwork. If only moderate to light buildup is present then there are chemical disinfectants specifically designed for use in air handlers that will kill the existing mold and mildew and control new growth. These disinfectants are safe and very effective and are applied by simply spraying into the filter intake and by placing "Algae Strips" directly in the drain pan. If the coil has mold or mildew present then it also should be treated. Make sure that the face of the cooling or evaporator coil is clean so that air can pass through freely. HOPE THIS HELPS :)
Jul 25, 2013 | Cars & Trucks
Goodman/Amana air handler freezing up and not cooling home. What could be causing it?
There are two things that cause freeze up's...
Low air flow...
Low freon...
First check the filters, the blower , and the air vents to make sure that the air handler unit can move enough air...not enough air across the coil, the coil gets too cold, ice forms....
The low freon problem will require professional assistance...
For the system to be low there needs to be a leak...the leak must be found and repaired or the fix will only be temporary...
To do this the system refrigerant must be recovered, the leak fixed and then the system vacuumed and recharged...
One other thing....outdoor air temperatures under say 65 F can also cause freezing.... but I am assuming that you are above that if you are running your A/C system.
AirConditioner Trouble - Review the Possibilities
heatman101
May 25, 2011 | Amana Heating & Cooling
Hi, After finding out that Freon is low by seeing snow/icy surface on outside compressor, I went up in the attic to find snowy/Icy surface all over the coil inside the air handler. I wahsed it and made...
Hello
Your still froze up.There is a freeze cutoff device in the air handler upstairs.
Look for a thin silver color tube near the coil and follow it to the control box,there may be a reset button.If not, try using a hair dryer to warm up the coil and it should reset itsself.
These freeze devices can take an hour to reset on there own sometimes,do not run the compressor while doing this.
Aug 30, 2010 | Ruud Heating & Cooling
The plenum that houses my coils sweated repeatedly and the coils seemed to freeze. An agent told me that my unit was leaking at the fittings to the outside unit as well as the coils . The unit he used to...
Hello JBESTER Defrost the unit completely and see if the pressures are low.If more than half the charge/freon(3+)lbs has to be added you have a leak.Make sure the air filters are new as poor air flow can cause ice also.The sniffer I use beeps all the time BUT when near a leak goes crazy!The coil can leak after 6 yrs.You will always will need a recharge untill leak is resloved.
Aug 25, 2010 | Carrier 38CKC036 Air Conditioner
I have a Ruud Achieve model UPKB 060 CAZ that has a line that keeps freezing up when the thermostat is set to go below 76 degrees. The freon was checked and some was added. Also, the air handler is in...
Normally when the suction line freezes which is the larger of the 2 lines, #1, its low on freon again and unit has a leak. They are sealed systems and they should never need freon only if they develop a leak. So, this we know. Also, if the air filter is dirty and plugged, and the evaporator coil at the air handler is dirty will cause icing of lines and coil.Not enough air flow across the coil due to a dirty filter. When you set your thermostat to go below 76 degrees, the unit will work harder to keep up to bring the temperature down and if you have a leak which you do, the suction line will ice up. A Ruud 060 is a 5 ton btu unit, good size. Who ever added freon should have done a leak check on it. I would recommend you calling them out as it is low again and do a complete leak check, add dye to the system or there are many ways to do this. If the leak is not found it will continue to ice up. By E.P.A. standards, they cant keep adding freon, they must find the leak.This is all about you can do, is check and make sure you have a return air filter and its clean, and if it continues to ice, have them find the leak, repair it, and re-charge it. I wish you the best.
Sincerely,
Shastalaker7
Jun 18, 2010 | Heating & Cooling
Last couple of years if our thermostat is set below 74 the ac will freeze up. The last 2 years we had it checked out and were told that 1)coils might be going out and 2) needs more freon. Once freon was...
Hello
If your going to have all the freon taken out,this current tech needs to find the leak.
Clearly from what you have said the unit has a freon leak.Freon is put in by ounces or pounds depending on the size of the unit,then you need to get the correct operating pressures.Coils do not go bad they either get full of dirt or get a hole in them.
An 8 yr old unit is a tough call,surley a new one will probably save some electric and come with a warranty.I would get some quotes on a new one,then see how much i could spend.
May 20, 2010 | Fujitsu Heating & Cooling
I have a Ruud Achiever High Efficiency heat pump manufactured in 02-2002 model # UAMB 024JAZ 60 Hertz that the coils in the air handler inside the house freeze and won't cool the house. Our environment is...
Indoor coil freeze-up is always caused by lack of airflow over the coil. Check your filters, check the coil to be sure it has not been blanketed by dust that bypassed ir went through the filter, check that all vents in the house are open.
Indoor coil freeze-up is NEVER a condition of undercharge, and any technician who attempts to make frost go away by adding freon does not understand thermodynamics.
The only other reason you could have freeze-up is the unit is over-sized, but I suspect that is not the problem since you have had it since 2002.
Dec 10, 2009 | Ruud UAMB Air Conditioner
What causes my evaporator to freeze up
This can be caused by a few things.Check for a clean air filter. If the filter is dirty the air flow is slowed and lets ice form and over time the coils freeze over. The next thing to look for is a dirty evap coil. Same thing. if the coils are dirty the air flow is restricted and causing freeze ups. if this all looks ok then its time to call in the pro's. For environmental purposes all HVAC techs are citified to handel freon in the correct way. They will check the system for leaks and repair them followed by a freon recharge.
May 11, 2009 | Heating & Cooling
Inside unit freezing
There are varius items that make the unit inside (air handler) freezes up .If the fan motor in the air handler doesn't work it'llice up.If the filter is dirty it'llfreezes up. If the coil in the air handler is dirty it will freezes up.And if the unit is low in refrigerant(freon) it'll ice up.If is low in gas means there's a leak and before recharged it needs to be fixed.
Apr 23, 2009 | Heating & Cooling
Goodman CKL42AR42 Air Conditioner Logo
170 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
