Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Dream maker spa x-400 won't shut off keeps heating
  • 1 more comment
  • Charles East
    Charles East Sep 08, 2010
    You need to provide some clarification on this issue. How hot is it getting? What is the ambiant temperature in the area where the spa is located?. Is the spa pump (circulation) running constantly or more than 2 hours during the filtration cycle? What temperature is the spa set on? Is the spa heater light illuminated during the overheating? Are you hearing any water boiling noises after the pump shuts off?. Are you seeing any error codes displayed?
  • Brian Walter Jan 18, 2013
    Did you resolve this issue.. Mine Keeps running until it over heats.. It gets up to 105 Degrees
  • Jim Ridge
    Jim Ridge Jan 15, 2015
    I have the same issue. It is set at 104. Outside temp ranges from 35 to 75. Motor runs until temp is sometimes 107 and above. error code comes up (OH) but spa does not shut off. When it finally does shut off, error codes stays on even after temp has dropped into 70-80. i hit the pump button and it comes on but does not shut off at designated temp. I have tried resetting, leaving unplugged to help reset. but when plugged back in it just goes and goes until it hits OH.
    Top Expert:
  • Dream Maker ... Master
  • 5,779 Answers
Bad temp sensor
Posted on May 11, 2016
jj505
  • 195 Answers
SOURCE: dream maker 400 cover always fill with water
You will need to either get a new cover or buy a new extralarge tarp and use as cover. Thanks jj505
Please rate
Posted on Apr 05, 2009
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12650 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
My dream maker spa comes on for about 2 min. Then
it is over heating.. I would call the dream maker spa people and see if there is a service person in your area! I could fix it but I live in florida!
Aug 28, 2014 | Pool & Spa
X-400 wont shut off
How cold is it? It may be sensing an ambient freeze condition.
Jan 20, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 | Pool & Spa
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power is on but jets arnt going and pumps not pumping
I was looking for an answer to your question. I have the same problem with my Dream Maker X-400 and it is less than 2 months old. The power is on but the tub is not heating now, its down to like 82 degrees and the pump is not working but it has power. It just stopped yesterday.
Dec 18, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
1,346 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
