Question about Refrigerators
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only for a short time then stops. When water stops pouring light turns off. LED lights for crushed ice and cubed ice will turn on only for a short time after hitting buttons. Lights turn off when trying to dispense and will not get ice" For us we hear a clicking noise all the time. Now the lighted numbers in the refrigerator showing the degree of coldness/temp of both frig and freezer turn off and we catch it and turn them back on. The problem started when the water from the frig dispenser would work intermittently. Now it does not work at all. Ice doesn't come out of the dispenser either but yet the freezer will make ice into the bin inside the freezer. The lights on the frig dispenser are dim and turn off. If you touch this light button by the water dispenser and turn it "on" it turns off the lighted numbers in the refrigerator showing the degree of coldness/temp of both frig and freezer and the clicking stops!! As soon as you hit that light button by the water dispenser again, the lighted numbers in the frig turn back on. This frig is going down fast!! I assume it is the compressor, the compressor fan or the mother board.
  • Refrigerators Master
  • 1,606 Answers
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Posted on Sep 08, 2010
5 Suggested Answers
  • 744 Answers
SOURCE: kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: ice dispensor only dispensing crushed ice - not cubed
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
  • 1126 Answers
SOURCE: only puts out crushed ice
Pull out the ice bin and set aside. On the back wall of the freezer where the auger drive coupling is, to the right and down below the locator pin, is a square opening....make sure that the actuator is in the down position. if stuck in up position, it will always crush the ice. We have had the same problem with our frigidaire. The actuator is connected to the "crushed ice" solenoid.
Posted on Aug 18, 2009
Testimonial: "Your help was wonderful---THANKS"
kel1guy2002
  • 3740 Answers
SOURCE: Model PSC23MGMA BB GE side
Hi and welcome to FixYa, I am Kelly.
I think that the door flapper spring is broken or disconnected: PN WR02X10585
http://www.repairclinic.com/GE-Refrigerator-Model-PSC23MGMABB-ID-617640-Spring-Parts
It is item 63 of the below link BUT, it not listed in the below link so see above for ordering:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219346
If there is a problem with the solenoid item 36 above, it can also cause the frosting problem:
Sears parts direct also has parts for this unit here:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC23MGMABB/0432/0165000/G0104039/00001?blt=06&prst=&shdMod=
I am sending this now and will look uo the crushed Ice problem and respond again soon,
Thanks for choosing FixYa,
Kelly
Posted on Jul 29, 2011
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Ice maker works,but cannot get cold water function to work
Dual water control valve on rear of your refrigerator. The side for the dispenser must be defective and the pair need replaced. It can be OHM tested or someone can unplug that side and check for 120 volts ac while someone presses dispense water. Sea Breeze
Mar 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No drink water come out. however ice maker still work.
Your refrigerator separates the water control into two parts. One side for water and the other side for dispenser. Have someone unplug the dispenser side and test for 120 volts at the female plug disconnected to the dispenser side while someone presses dispense water. You should show the voltage. Another way of testing to OHM both coils and see is open. shorted or almost same measurement of OHMs The part number for the water control valve is Click Here=> WR57X10032 If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com Thanks, Sea Breeze
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice maker doesnot work ge artic profile
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes and then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
You may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile TFX27PFSM diagnostic is flashing de
DE means something is wrong with defrost system. Here is your user manual=> TFX27PFSMWW the notes are on page 8. If you need assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Dec 25, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
GE GTS221 refrigerator not ool or cold at all
If yours is the model number GTS22IBMA you most likely have a motherboard problem caused by a bad fan motor or bad start components or even electrical surge. I can help you do the repairs if you like. You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Thank You, Sea Breeze
At bottom of this page are the parts you may need but until I have someone on your end to use a multi-meter I wait to decide the real problem. HERE=> SEA BREEZE TECH PROFILE/ARTICA There also is a service manual on that page to download.
Dec 13, 2009 | GE Refrigerators
Refrigerator is warm in top half only
This will need to be checked out soon. If you are interested in doing this yourself you will need to let me know. Hopefully your refrigerator is only having a problem with a bad defrost heater and defrost thermostat. I will not say that I have a simple answer on the problem but the most likely reason is a burned out defrost heater. I will be back soon with everything you will need to consider,
Nov 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE profile is not dispensing water and ice
Either your dual water control valve is defective on both sides or you need a new door switch. Have someone check the power to the water control valve wile someone presses dispense. Sea Breeze
Aug 25, 2009 | GE Refrigerators
Refrigerators Logo
209 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
