Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
I have an early model john deere 3020 gas and am having problems with it running rich. It has electronic ignition to replace the points and I put new wires, coil, and plugs in this spring but it still runs rich and idles high when it gets warm. I had RDO in town rebuild the carb and it seems worse that before. It has a zenith carburetor on it. RDO said that they could not rejet the carb and I think that they are wrong. Does anyone have any ideas for me or can anyone tell me where to buy new jets for these Zenith carbs? Thanks for any help you can give.
2 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
Torque specs for the intake and exhaust manifold bolts 3020 gas
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
1964 john deere 3020 WORKSHOP SERVICE REPAIR MANUAL
Jan 08, 2016 | John Deere 3020 Gas & Diesel Tractor...
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
Have a John Deere 3020 with a Marvel-Schebler carburetor. Not staying running seems like its out of gas and it is getting fuel it runs a short wile and dies pump the fuel pump manual pump and it runs for...
Have you checked that your float is working properly in the carb? If it is sticking with the plunger shut it will block fuel inlet regardless of having fuel supply?
Have you checked to see if there is definitely fuel in the line at the carb when it's acting up?
Have you made sure that there is still spark when it quits running? You could have something that is grounding out when it warms up and makes it quit firing that while you 'fuss' with gas issues, cools enough to spark then fails again. Hard to say without more details. Also are you sure there isn't a clogged fuel filter in the tank, carb-inlet or inline somewhere?
Oct 06, 2013 | John Deere Garden
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
159 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
