Question about Dishwashers
Bosch SHE56C05UC dishwasher. My Bosch ON/OFF switch is very difficult to depress. I have to push it so hard I know I will eventually break it. I removed the control panel and tried to clean it but to no avail. I want to find out how to fix it. If I have to buy a new control panel just don't tell me and don't charge me. Fair enough?
  • Dishwashers Master
  • 3,247 Answers
I believe you can get the on/off switch separately for this model.
Appears to be moderately priced. Hope this helps.
Posted on Sep 08, 2010
  • Sam Sep 08, 2010
    testing response
I have a Bosch SHE56C05UC/40. The unit fills and drains ok but the circulation pump will not operate. I run the diagnosis according to another of you posts and came with an error code E1 which is a heating...
follow the instruction code in your ins.manual if you do not have go for free download : www. fitness.manualsonline.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Bosch SHE56C02UC / SHE56C06UC Dishwasher
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
SHE56C05UC - full of dirty water at end of cycle - filters and drain system seem not to be blocked
I would still try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 13, 2009 | Bosch Dishwashers
BOSCH DISHWASHER Flooding
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case...
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Jan 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Dishwasher on/off
It could be the switch. If the black plastic On/Off button comes all the back up into cutout in the top of the door, you must remove the front of the door (10 little screws; two shims will probably fall out; good luck figuring out how they go back) and then the plastic top (4 little screws) that contains the On/Off and the wash mode buttons. Now you've exposed the real on/off switch, which has a reddish/brown stem (at least on my unit). Test the switch; if the DW doesn't stay on when you depress it, you need a new switch. If it stays on, then goes off when you depress it again, the switch is likely good and maybe you have a problem with the black plastic cover button.
May 30, 2008 | Bosch SHU9950 Dishwasher
Bosch dishwaser
need to look at operating booklet and see what F stands for.then rectify it.
Oct 05, 2007 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch dishwasher digital readout
It sound that the problem is cause the water level switch.The switch level is a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Aug 14, 2007 | Bosch 24 in. SHE56C05UC Stainless Steel...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
Owen Barnes
