Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower mod.# AYP 7143A69 approx. 2004 year model will run fine 30 min to mabey an hour then dies and will not start back up till it cools off for an hour or two. I checked the coil resitance and it is ok when its cold. could it be a carb problem or what do you think I should next. thanks
rockitman187
  • 2559 Answers
SOURCE: cranks ok. no spark.
Sounds like the coil,condenser or both are bad.
Posted on Apr 05, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
Posted on May 22, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 138 Answers
SOURCE: craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Posted on Aug 17, 2009
Riding lawn mower starts runs good for a out 15min then stalls and dies. Few min later starts up then same thing.
shortage of fuel is indicated
check for full flow to the carby
next is faulty coil --overheating
make sure that the cooling fins are not blocked with old grass and muck
Jun 25, 2017 | Craftsman Garden
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
I have craftsman Riding mower modle#917.289213 and want to mount a MTD 190-833c-OEM. Has somone out there ever run into this problem. I first purchased the riding mower, and the called Husqvarna and...
I have never run into this problem. Craftsman riders are manufactured by American Yard Products (AYP) and are owned by Husqvarna Co. MTD is their own manufacturer. I would assume that if you want to hook this MTD blade to an AYP mower there would be some "back yard engineering" necessary. If there is an adapter available to hook it to your mower, either AYP or MTD should supply that adapter. Not much help for your problem, so I hope you get it figured out.
Feb 17, 2011 | Garden
Craftsman riding mower shuts off after approx 20 mins of use.
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
