Question about Asko 24 in. D3250 Built-in Dishwasher
My Asko 1473 Superior dishwasher has just stopped filling. I've gone through the on-board diagnostics and find that the fill solenoid operation does not work. All other diagnostic tests are OK. I have no service manual but would like to find and replace the solenoid if that is all that's wrong. Can you help with advice or manual? cheers, Hal
Asko
Posted on Jan 14, 2011
Mains on/off switch issue asko 1473 superior dishwasher
then call a repairman and have that control replaced .
Dec 24, 2015 | Asko Dishwashers
D1876 Asko dishwasher doesn't fill. It runs fine if I manually fill the unit with a couple of pitchers of water. Likely culprits seem to be a faulty water level sensor or water fill valve. Any...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1876 and 2) not filling with water...It sounds like a faulty fill valve/water valve unfortunately.
First though, you can perform a diagnostic/fault trace program by following the steps below. You should hear the valve starting once the unit has started filling with water.
You'll need to be familiar with the control layout for the test to begin. This is how the buttons/display is identified in the diagnostic...
Now you can enter the fault trace by way of the following sequence....
Obviously based on the instructions if you push S3 the valve should open and allow water into the tub, this image below indicates the normal water level to look for when filling in the normal cycle NOT FAULT TRACING...Fault trace will fill until you stop it.
This unfortunately is common with Asko built dishwasher`s, but it can be fairly easily repaired with a little direction/know-how.
**First turn off the water and the power to the dishwasher...safety first**
You should only need to remove the toe panel/kick plate at the bottom and of course turn your water and power off, undo the water line at the valve,
i.e.
...remove the two torx screws ( large arrow ) and then the delivery hose at the back of the valve ( small arrow ) and install the new one.
The new valve is part # 8801351 and available at on-line parts depot "repairclinic.com" for about $170USD last time I looked.
Let me know what you find and I'll try and help you move forward from there...you may opt to call in a pro but that's up to you.
I'll watch for your reply.
Regards,
Macmarkus :)
Jan 30, 2011 | Asko D1876 Dishwasher
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Dec 31, 2010 | Asko Dishwashers
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
Asko dishwasher starts and immediatly stops
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Apr 22, 2010 | Asko 1595 Dishwasher
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Jun 30, 2008 | Asko D1716 Built-in Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
DISHWASHER
Make sure you have water coming to the dishwasher. Next check your dishwasher float. Make sure it is not sticking. If not you could have a problem with your fill valve. Check for voltage at the fill valve if you have 120V then you need a valve the solenoid is defective. Replace it.
Dec 24, 2007 | Dishwashers
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
396 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
