Question about Whirlpool Duet GHW9150P Front Load Washer
My washer, model number GHW9100LW2, is stopping when it gets to the drain/rinse cycle and showing an error message F2 on the display. What does the F2 error message mean?
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 08, 2010
Machine stopping prior to rinse cycle, not draining.
Hi Jackie, more than likely you have a timer control failure. It's an easy fix if you have money and can afford a repair man to fix the problem. It's a lot better plan if you have friends with a few skills. Just need to enter model number of your washer on ebay and ask for a replacement timer. It is behind the cycle control knob on your washer. Invite a couple friends over for a cookout and repair your washer. Don't have any friends? If close enough will be glad to help. Simple fix, have fun, good experience. Stan
Apr 02, 2017 | Kenmore Whirlpool Duet Sport Washer Door...
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
Washer will stop after rinse cycle and says OE. Then is will not drain rinse water.
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | LG Washing Machines
Doesn't drain in rinse mode
Hi just read your posting.Now when it stalls in the rinse cycle does it start to beep and light up a couple of lights to indicate a fault code? Or do you have the LCD display model that shows the error code.If your machine shows some light on the same line of lights, there are 8 in a row , which ones are lit? Is it the 2nd and 4th or 1st and 6th--etc .Also if you have the LCD display model what is the error code?Please reply for further help.Hope this helped.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
158 people viewed this question
Dan Webster
Dan Webster
Sal De
