Question about Kenmore Heating & Cooling
Boughta new water heater, got it instold, now there is no hot water
  • Brian Kirk
    Brian Kirk Sep 08, 2010
    Is the water from the water heater turned back on? Is the power on to the heater or if it's gas, has the gas been turned back on and the pilot lit? Who installed it? Have you checked with them? Do they warranty their work?
  • 456 Answers
Is is electric or gas? If gas did you light the burner? If electric
did it get wired properly 220volts and is the breaker on? Did you turn up the thermostat in the lower panel? Did you open the inlet water valve and then open all your fuacetts to get the air out?
Posted on Sep 08, 2010
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
Tip
How to install a Water heater
Step one removal of the old one start's with turning the power source and water off to the water heater.
Once power and water is off connect a water hose to the drain on bottom of water heater to start draining. Open the drain and the hot side to a faucet to help water drain quicker.
Once drained and new heater their to go back in. Remove old one and reinstall new one.
Connect wires and water lines to new heater and turn water on first to heater once everything is connected.
Let water run til you get all the air out of tank and water running from hot side on all faucet's throughout house before turning power on to heater.
Once all air is out of tank and water flowing from all faucet's you can turn power on to new heater and about 30 to 40 minutes you should have hot water.
on Jul 13, 2010 | Plumbing
How to remove a hot water heater and replace a new one ?
Seems like if you need to ask such a general question, you need to call for help...a plumber
May 07, 2015 | Water Water Heaters
Cold water connection is hot
Did you put hot to hot side? And cold to cold side?
Cold water pipe usually has shut-off valve.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Add comment and say brand and type of water heater for possible follow-up
Mar 23, 2013 | RELIANCE ELECTRIC WATER HEATER
Power was shutoff to house at pole all breakers were off.power restored breakers turned on took ashower next day no hot water breaker tripped will not reset water heater reset doesnt work either i have a...
according to your problem, the power was cut to the house; then power was restored and everything went back on that was on except the hot water heater. when you tried to reset the water heater breaker, it wouldn't reset. the hot water heater also won't reset. the problem is not w/the breaker, the problem is w/the hot water heater. you need to buy a new reset for the hot water heater which means a new control unit, since the reset is hooked to the contol unit. this is answered by an electrician w/35 yrs experience. the breaker controls the hot water heater. since the breaker won't reset, the problem lies in the control unit for the hot water unit.
Mar 08, 2011 | Kitchen Ranges
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
New hot water heater cause smelly hot water.
U can clorinate ur water heater 1 gallon will do it. But you should try changing the anode rod(to aluminum) or removing it first followed by a complete drain, purge and refill.
Mar 29, 2010 | Water Heaters
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
19 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
