Question about Olympus FE-210 Digital Camera
When running on batteries, camera lens stays open and camera shuts down. When plugged into PC, camera lens will close.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Also, please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 08, 2010
My camera lenes wont stay open
Usually the lens closing is a sign that the battery is dying. If there's not much power left for the camera, it will first close the lens so it's protected before powering down. Make sure you have fresh batteries, fully charged. If the battery is going bad it may not hold a charge for very long but appear to be charged when you first intall it.
Dec 25, 2014 | Kodak EASYSHARE M340 Digital Camera
When you turn on the power it stays on briefly and shuts off.i have already replaced the batteries
The camera is on an error as it shuts down, can be due to failure of the lens control system/main servo or control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of opening to check for any jammed mechanism. If this is hard for you, then it will be good to have it checked at a service for estimate as you do not have to run around for spares.
Dec 20, 2010 | Polaroid I533P Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
KODAK Z1275
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Sep 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
Olympus FE-210 Digital Camera Logo
23 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
