Question about Video Cameras
How do you change the batteries on a zenith cassette adapter model number VAC615?
Samsung camcorders
You'll have to tell us what "this" model is. The model number of the battery charger doesn't tell us much about the camcorder itself.
Feb 02, 2012 | Samsung VP-W60, VP-W60B, VP-W61, and...
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
How to open jvc c-p6u cassette adapter?
Change the AA battery. I did and the switch worked and it ejected.
I had no idea there was a battery involved.
Panel on left end
Aug 15, 2011 | JVC CP6U Adapter
RQ A200 cassette player stop working
If your battery polarity was reversed then there is a possibility that a protection zener diode onthe set could be short as a prevention. so you will have to check on the + line input to the set. If not the amplifier could have shorted depending on the applied power. Anyway you will need a good check onthe main board to confirm this but I think with a tech help, it will not be difficult. Hope I could help. Good day
Jun 12, 2010 | Panasonic RQ-A200 Personal Cassette Player
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Can get my cassette adapter for my ipod to work it keeps ejecting the cassette
I also have a '95 ford explorer. Same problem. I took the screws out of the tape and opened up the adapter. I took out all the gears EXCEPT for the one large one in the middle two on either side. Now it works perfectly.
Nov 19, 2008 | Audio Players & Recorders
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
My VCR is egecting the tape with the casstte adapter.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
52 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
