Question about National Geographic 76AZ (525 x 76mm) Telescope
How to install the eyepiece - National Geographic 76AZ (525 x 76mm) Telescope
  • 3,186 Answers
Is your scope like the picture? If it is it is a REFLECTOR style with a mirror on the bottom.
Put the eyepiece into the focuser-- this is the UP end of the telescope. The large mirror is on the DOWN end. I have seen many beginners mount these upside down with the open end pointing at the ground!
Read this:
http://www.texasastro.org/telescope.php
and my TIPS on my profile page.
Posted on Sep 08, 2010
Ido not know how to assemble it. The instructions are generic for all their telescopes. Where do I out the different lens that came with it? How do I install them? Help please.
The lower the number on the eyepieces the HIGHER the magnification. The 2x barlow DOUBLES the magnification of each of the eyepieces. To start just put the eyepiece with the largest number written on it into the focuser, and use that ONLY until you learn how to focus properly.
The eyepieces fit right into the hole in the focuser.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 23, 2011 | Tasco Luminova 40114675 (675 x 114mm)...
I need the eyepiece for the vivitar refractor telescope ot accidently was broking when I shipped to the Bahamas
You don't say whether this is an astronomical telescope or a terrestrial one (spotting scope). However, I have a Vivitar scope which was sold as an astronomical scope, but is actually a spotting scope, although it uses astronomical style eyepieces, so...
I am not sure that it is the eyepiece you want, either. It is hard to break an eyepiece, but much easier to break the eyepiece mount or diagonal mirror fitting.
Most astronomical telescopes use a standard fitting eyepiece with a 1.25 inch outside diameter barrel. You can measure the mount where the eyepiece goes to make sure that yours is this size, then search on eBay or Amazon for "1.25 eyepiece" and you will find many available. It doesn't have to be made by Vivitar, any make will fit.
The other variable will be the focal length of the eyepiece, which is what determines it's power. The power of the scope will be the focal length of the main objective divided by the focal length of the eyepiece, so a 9mm eyepiece will give a higher magnification (and be dimmer and harder to focus and find objects) than a 20mm eyepiece. It is usual to have two or three different focal length eyepieces for viewing different objects.
Jan 23, 2011 | Vivitar (1607225) Telescope
NATIONAL GEOGRAPHIC TELESCOPE NG76AZ where can i get a solar filter and additional lenses etc for above 76mm telescope
Do NOT attempt to look at the Sun through a solar filter! These can crack from the heat and you will be blinded instantly.
Most telescopes use a standard fitting eyepiece with a 1.25 inch outside diameter barrel. You can measure the mount where the eyepiece goes to make sure that yours is this size, then search on eBay or Amazon for "1.25 eyepiece" and you will find many available. None of these will be made by National Geographic, but any make will fit.
You will find a large variation in prices, which is partly due to the difference in quality and type of construction of the eyepieces. Kellner eyepieces are simple and cheap, whereas Possl or orthoscopic ones are more complex and cost more. There are reasons why people will pay more for the better eyepieces. Avoid eyepieces marked with the letters "H" or "SR" before the focal length.
Jan 20, 2011 | National Geographic 76AZ (525 x 76mm)...
The eye piece lens is missing. How do i find the model number of the telescope to order a new eye piece and a manul for this telescope
Most telescopes use a standard fitting eyepiece with a 1.25 inch outside diameter barrel. You can measure the mount where the eyepiece goes to make sure that yours is this size, then search on eBay or Amazon for "1.25 eyepiece" and you will find many available. None of these will be made by "Edu-Science", but any make will fit.
There is an excellent website for beginner telescope users at THIS LINK
Jan 20, 2011 | Edu-Science (10166) Telescope
Im trying to find an eyepiece for a Meade model#114EQ-DH telescope.
Most telescopes use a standard fitting eyepiece with a 1.25 inch outside diameter barrel. You can measure the mount where the eyepiece goes to make sure that yours is this size, then search on eBay or Amazon for "1.25 eyepiece" and you will find many available. Some of these will even be made by Meade, but any make will fit.
Jan 18, 2011 | Meade Infinity 114EQ-DH Telescope
When I look through the eyepiece all I can see is my own eye. I have a VIV-TEL-76700
The only thing I know of that can cause this effect is if you are looking into the eyepiece mount of a reflector telescope without there actually being an eyepiece in it. Seeing your own eye in this situation is a check that the collimation (lining up of the optical elements) is good.
You need to put an eyepiece into the mount. This scope is meant to come with two eyepieces, but if you bought it second-hand and didn't get them, you can buy eyepieces from several sources, including Amazon and eBay. Measure the eyepiece tube's inside diameter. The most common barrel size for eyepieces is 1.25 inches, but there are also some small telescopes that use eyepieces just under an inch (.965") in diameter, which are harder to find. If you have to buy eyepieces, they are likely to cost more than this scope is really worth.
There is a good website for telescope beginners at THIS LINK
Jan 15, 2011 | Vivitar (1607225) Telescope
Telescope Lenses
You don't need to get Vivitar brand eyepieces to get additional ones for your telescope. I'm not sure of the specifications for this particular telescope but in general they come in two barrel sizes for the eyepieces. The diameter of your eyepiece is probably 0.965" but could come in the more standard 1.25". You can measure the diameter and determine this quickly.
Once you know the diameter to shop for you can look for the focal length of the eyepiece you wish to purchase. They are rated such as 4mm, 10mm, 25mm, etc. The smaller numbers give you higher magnification. You can calculate the magnification by dividing the telescopes focal length by the eyepiece focal length. For example, let's say your telescope is has a focal length of 360mm and you have an eyepiece rated 10mm. Divide 360 by 10 and that gives you a magnification power of 36.
You can find eyepieces at many telescope dealers on the internet. Your selection will be far less if you use 0.965" eyepieces. You can purchase 0.965" to 1.25" adapters so that you can use the larger eyepieces with your telescope. However, on some telescopes the adapters will cause the new eyepiece to not come into focus.
You'll also find that eyepiece prices go all over the place. A good general purpose eyepiece is a type called the Plossl. The better eyepieces have more coatings too that allow more light to get through to your eye. You'll find these listed with terms like "fully multi-coated".
I hope this helps.
Good luck and clear skies!
-jodair
Mar 25, 2009 | Vivitar (1607225) Telescope
No lens
I am assuming by "lens" you mean eyepieces.
I hope this helps.
-jodair
Mar 05, 2009 | Vivitar (1607225) Telescope
Missing the eye piece for the Meade saturn 60az-m
ebay is a great resource for eyepieces, i would suggest a 26mm ma.
the eyepiece should drop in. if not you might be missing the image erecting diagonal. when the eyepiece is installed you should be looking perpendicular at the tube.
Nov 25, 2008 | Meade 60AZ-M Jupiter Telescope 60mm...
Eyepieces lost
You did not mention your telescope make and model so:
1. measure eyepiece holder. Determine of you use .965in. or 1.25in. diameter eyepieces. If you use .965 eyepieces you are limited in choices. HANDSONOPTICS.COM carries nice Plossls. SURPLUSSHED.COM. sells .965 moon filters and cheaper eyepieces. If you have a 1.25 eyepiece holder, the skies the limit on eyepieces. Check Ebay plus other sites.
2. Determine the focal length of the eyepiece you want to use. As a rule, your scope can magnify 50x per inch of aperture although looking at just the moon, you can stretch that a bit. For example, a 80mm reflector (3.1 in). x 50 = 155x max. magnification (must be a perfectly clear night)
So now find the focal length of the scope (stamped/labeled somewhere) Typical refractor is 700mm. For maximum power (155x) it is: focal length of telescope/focal length of eyepiece = magnification. Or FL (scope)/ magification= FL eyepiece. 700/155= 4.5mm. This size will have terrible eye relief unless you spend $$$$$. Suggest a 10mm eyepiece which gives 70x power and a great view of the moon and planets
Nov 15, 2007 | Tasco Luminova 40114675 (675 x 114mm)...
National Geographic 76AZ (525 x 76mm) Telescope Logo
133 people viewed this question
Top National Geographic Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Tom Chichester
Are you a National Geographic Optic Expert? Answer questions, earn points and help others
