Question about Sony Cyber-shot DSC-W30 Digital Camera
When turned the camera just says access - Sony Cyber-shot DSC-W30 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Also, please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 08, 2010
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When I turn on my camera it says there is no space in internal memory. How do I access internal memory to delete images?
please remove your memory stick & then turn on the camera then you will able to access your internal memory
Apr 28, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My camera Access and then say turn the power off and on again
Camera needs to be serviced. The camera got dirt in it and needs to be taken apart and cleaned. This should be done by someone with knowledge of cameras because they consist of many parts inside.
Jun 17, 2009 | Sony Cameras
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Access error
turn on take hold of the end of the lense then gently pull and twist you may hear a click but dont force it then turn off and on again and the problem should be solved
Aug 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Access across the screen
Keep the camera without the batteries for 10min.. also format ur memory card in the camera.. Dont fill up the internal memory space..
Thankyou
Apr 12, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Access and turn on again the camera
I called Sony at 800-222-7669 and was told to turn camera off, remove battery, turn camera on holding the power button for one full minute, put battery back in and power up as usual. Probably the one minute drains the residual energy in a capacitor.
I passed the info to my wife but she had solved the problem by tapping on the front to release a bind on the lens coming out. Probably caused by handling during her trip to California. So I don't know if the one-minute thing works but it is certainly worth a try.
Hope this helps you!
Dec 29, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Getting access
Was your unit dropped, or maybe left with the lens protruding? Seems you have a problem with the lens assy(stucked), during start-up, it will initialize to check if all systems go, if not then it will display turn off and on again. thanks
Sep 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Screen only shows "access"
One of my friends has the same problem with her camera, but we can't even get old pictures to come up on the screeen. When you turn it on it says access for about 15 seconds, then tells you to tell the camera off and then back on.
Aug 22, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
