Question about Thermador SEMW302BS Stainles Steel Triple Oven
Thermador microwave is arcing and sparking - Thermador SEMW302BS Stainles Steel Triple Oven
  • Thermador Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 08, 2010
How do I replace spark igniter on my thermador oven
what is the model number? there are too many models to be generic in an answer for you. Most Thermador gas OVENS use glo-bar type ignition.Are you speaking of the top burner igniters? you have too many parameters open here for anyone to give a proper answer to you.
Jan 19, 2015 | Thermador Ovens
The microwave unit on my Thermadore CMT231 (integrated microwave convection oven) has suddenly stopped functioning. I suspect a fuse has blown. Is this a self-serviceable part? I am a complete novice, but...
No to novice work! get yourself or your family killed (although you might do Darwins' work for him.....)
Yes to fuse, check the HV fuse and try replacing it. if it blows again you have a serious fault and need a micro tech.
PS expensive :-(
Oct 14, 2013 | Thermador Ovens
Microwave stopped working
heatman101
Apr 16, 2011 | Thermador SMW272 Electric Double Oven
Need to replace microwave - current Thermador model is too big. Does anyone know of one that will work?
Did you ever get an answer to this? I have the same problem. Did you have any luck with a solution? Thanks!
Dec 16, 2009 | Thermador SMW272 Electric Double Oven
I have a Thermador model CM302 with a built in microwave. The microwave makes all the right noises ... but does not heat the food. What's the problem?
I have the same oven and the same exact problem. The problem is with the magnetron. It needs to be replaced.
Nov 20, 2009 | Thermador Ovens
Thermador smw272y won't heat at all
The switches on the first circcuit card mounted horizontally in the space above the microwave enclosure and behind the control pannel have burned to the point that they no longer engage properly to close the power to the oven heating elements. I do not know anyone who has removed the plastic covers and cleaned them to the point of working again properly and do not recommend trying that approach. The only sure solution is to replace the circuit card that has the three switches.
Sep 01, 2009 | Thermador SMW272 Electric Double Oven
Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Oct 17, 2008 | Thermador Ovens
Thermador sm272zs microwave/oven combo
You have to slide the oven partially out of the wall and there is a metal cover panel on top...remove it and you will be able to access the wiring panels, etc.
Dec 03, 2007 | Thermador SMW272 Electric Double Oven
Thermador SEMW302BS Stainles Steel Triple Oven Logo
212 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
