Question about Garden
I have been told to coat the bottom of my new lawnmower with fiberglass coating to extend the life of the body- is this true, or even a good idea?
  • 43,501 Answers
While it may extend the life it may also trap moisture and rust it out....also could be rough and catch the grass causing other issues...overall it probably is not a great idea...your mower will probably have something else go bad before the deck anyway...
heatman101
Posted on Sep 08, 2010
Have shutters front of house fadded...tried everything except paint...sun fadded terribly....any ideas to bring back luster? Tried Amoral but rain washed off..ideas appreciated.
several mfg of coatings nowdays offer , spray applied coatings that work on plastic and tin shutters well, ask at your local paint store for them , also make sure you remove the silicone coatings you have applied previously to allow coatings to stick properly
Jan 29, 2016 | Cars & Trucks
Can a fiberglass side panel be powder coated?
do not think that can be powder coated .
Oct 10, 2015 | Honda Motorcycles
NEED INSTRUCTIONS FOR EPOXY REPAIR KIT
If repairing a fibre glass bath you have to understand that the main bath is fibreglass and resin with a top coat . grind back to fiberglass top and bottom of repair , to reinforce place fibreglass patch mixed with resin under bath = top is jel coat . after repair cut back with wet and dry emery cloth .and polish= easy yes.
Mar 30, 2014 | Maax Home
What problems or benefits will I get with an aluminium boat hull
Aluminum boats are easier to maintain, will last longer than fiberglass, and are easier to repair. You can also bump into things without causing damage like you would to a fiberglass hull.
The only real advantages to fiberglass are that it looks better due to the gelcoat finish, providing that it is maintained, they also feel more solid in the water due to the extra weight, and they tend to ride better and are quieter than an aluminum hull.
One other consideration is whether you will operate it in fresh water or salt water. Salt water can lead to corrosion problems on an aluminum hull if you leave it in the water. Fiberglass doesn't have that problem, but you can have a problem with blistering if you leave a fiberglass boat in the water for long periods, especially if you don't use a bottom coat of some sort.
If you do opt for an aluminum boat in salt water, just make sure that you spray it down with fresh water and wipe it down with a soft towel whenever you take it out of the water. This is actually a good practice for any boat, aluminum or fiberglass.
Mar 28, 2013 | Boating
I just received the family canoe my husband had when he was little from my sister-in-laws who has kept it in the back yard for the last 12 years. It is in need of some TLC. The paint has wore off in...
Go to a local marine/boat store. They carry fiberglass repair kits for boats that should work on the canoe. There are systems out there that will coat the canoe and make it last a long time. They also have gels that restore the shine to fiberglass that are pretty amazing, but you would not want to put that on before restoring the damaged areas. Using marine-grade plywood would be a good start, but then seal it with a spar varnish in a can to give the wood a long life. The crack in the panel should be sealed as water can collect in that space, hopefully the outside hull only has the cosmetic cracks that can be filled before re-gel coating it or polishing it.
Aug 29, 2011 | Dolphin Boating
This is a general question: New brake rotors and drums are usually delivered with some kind of antirust coating. It can be a thin layer of oil, or some primer type paint. I was told, before installing...
Remove the oil or any other coating on the surface's where the brake shoes or pads make contact. This area should be cleaned before installing brake shoes/pads. As for the sand paper for the surface, it is a good idea to lightly sand the contact surface, but just lightly. What is also important is applying anti squeal to the backside (metal side) of the brake pad before installing, and also apply a small bit of grease where the brake shoe hits the backing plate (high spot on the backing plate, there is most likely four raised areas total for each side) on the rear brake assembly....just a small amount will keep the rears from making noise also.
Feb 17, 2011 | Chrysler Neon Cars & Trucks
I'm painting a fibreglass bodied car,it needed quite a few repairs and so after applying bondo and flatting I first shot 2 coats of primer wet flat with 800 but I could see the original paint and filler in...
I don't understand what you are doing here. What ford has a fiberglass body 800 is to corse thats why it went flat you need a sealer and you don't say what kind of finish or primer but then it sounds like you have got fixed so i don't know
Jan 06, 2011 | Ford Bronco Cars & Trucks
Cracked acrylic targa top corner
i believe that piece would be fiberglass with a coating of good quality acrylic paint. be that as it may if you are handy with fiberglass you should be able to repair it yourself. if not just about any body shop should be able to do the repair. get estimates from a few places first.
Sep 02, 2009 | 1988 Chevrolet Corvette
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
