Question about Harley Davidson 426290 AM/FM Radio
I have an 03 Ultra Classic, with a 76146-04 cd cb am/fm radio. A few weeks ago I was working on my bike and had my tour pak off and the CB antenna wire contacted the positive battery post and caused a small spark like it just brushed it. After that the radio tones would not adjust that I could hear, you could see the indicators move for both treble and bass and the sound was scratchy like it was not tuned in very well, I mostly listen thru the headset it was bad, so I sent my unit to radio sound for an exchange, now the speakers sound good the tones will adjust but the headset sounds bad, I have 2 top of the line JVC headsets and a Harley headset all sound rough. All of the wires I can see look good, plug connections look good to me. Any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
When you shorted the CB ant cable, you may have burnt the ground wire in the headset connector
Posted on Oct 17, 2010
1998 ultra classic am/fm/cb radio works good except cb it receives excellent but wont transmit
More than likely the "Final Power Output Transistor" has been fried due to a bad antenna or no antenna on the radio when someone tried to use it.
If you know how to solder you can find a replacement transistor at Digi-Key, Mouser or JDR-Micro Devices.
Its a fairly common problem and easy to fix. good luck
Dennis
Aug 21, 2017 | Radio Communications
HOW TO CONNECT CB ANTENNA ON FLTK?
Are you attaching a hidden antenna or a rear fender one OR a tour pack one??
There should be a wire waiting under the seat and you will just connect there and if a tour pack installation and you do not have he wiring already in place under the tour pak internal covering you will need to get a harness extension kit. Under the front cowl you would just plug into the radio or cb module.
May 30, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
2005 HD ELECTRA GLIDE ULTRA CLASSIC ANTENNA REPLACEMENT WHICH IS CB AND WHICH IS RADIO NEED INSTRUCTIONS
YOUR CB IS ON THE RIGHT AND RADIO ON LEFT AS YOU ARE STANDING AT THE REAR OF BIKE LOOKING TO FRONT HOPE THIS HELPS YOU
May 25, 2011 | 2005 Harley Davidson FLHTCUI Electra Glide...
My 2010 Ultra Classic with 200 miles has cd skip. Store bought home made and mp3 all skip. Bike was ok for first 50 miles. Sometimes it switches to the weatherband. Plugged in ipod as alternate and...
Radio switching to weatherband is an indication that the weather alert function of the CB is turned on. If the weather channel transmits an alert signal, it will switch to weatherband. Speakers cutting out may be your VOX setting is too sensitive or the squelch setting on the CB is too sensitive. Lower both the VOX and squealch and see if that works. If the issue continues, contact Iron Cross Audio for more help. www.ironcrossaudio.com
Sep 03, 2010 | Harley Davidson 426290 AM/FM Radio
Up grade radio on my electra glide classic
yes because you will have to run wires from the front to the back for the speakers unless your really good at wiring
Jul 27, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
2005 Ultra Classic CB transmits fine, does not receive at all . Replaced headset and cables, no luck.
Have someone check your SWR readings (using a SWR meter) on the antenna. This should give you some information on reception.
Jun 26, 2009 | Harley Davidson 426290 AM/FM Radio
Need best antenna for cb radio on ultra classic. Also, which antenna is the cb antenna, right or left
looking grom the back of the bike or tour pack cb is on the left of the tour pack, As far as antenna's i use 8 inch rubber ones
Feb 18, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
02 Ultra radio switches from cb to radio on its on
06 and newer CB modules have a weather alert feature that will switch to a radio station in case of an alert. The radio stations sometime transmit the signal by mistake. Check to see if your CB has this feature and if it does, turn it off
Apr 29, 2008 | Harley Davidson 426290 AM/FM Radio
Cb radio
You may be generating a harmonic from the cb that is picked up by the radio. Check if different channels and if AM/FM act the same. Also if a cd unit, does playing a cd produce the same effect. If all stations and the cd player do the same thing, interference is most likely coming in on the radio power or ground leads. You can get an inline noise filter from radio shack: http://www.radioshack.com/product/index.jsp?productId=2103979&cp=2032058.2032230.2032273&parentPage=family
or you can make your own if you have an old computer power supply by using the toroids if you can get to the power supply lead. Make sure the radio housing is electrically connected to ground. The interference may also be coming in on the radio antenna. Try moving the cb antenna away from it if possible, or test by rotating the cb antenna to a horizontal position temporarily.
Oct 26, 2007 | Radio Shack TRC-503 CB Radio
Harley Davidson 426290 AM/FM Radio Logo
537 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
