Question about Hoover Washing Machines
Hoover 750 LC top loading washing machine. Starts
Hoover 750 LC top loading washing machine. Starts cycle, sometimes goes all the way through cycle, at other times will stop part way through cycle and all that happens is a clicking noise. Can sometimes get cycle to continue by moving timer forward. Also, spin dry does not work sometimes, other times is OK. I think the problem is the timer but would like an opinion. Thanks
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
gittos73
  • 244 Answers
SOURCE: Hoover WDM120
this will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Posted on Aug 22, 2007
  • 183 Answers
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
  • 351 Answers
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Posted on Oct 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: hoover washing machine 550MB will not reliably go to spin cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Sep 18, 2017 | Hoover Washing Machines
Hoover 750 top loader goes through cycle drains but will not spin if you manually put it in spin it will not stop fills up and rinses drains but will not go again into spin until manually do it then again...
Two issues are possible , After the first start of the wash , check if the machine starts only when the water level is reached- to confirm the working of the water level sensor.
Secondly if the program cycles seems out of hand then it is possible there are errors in the program controller unit.
Apr 21, 2011 | Washing Machines
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hoover 750 l top loading .......wont spin proporly
check the lid switch its not working or its already cracked open
Dec 15, 2009 | Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Dec 29, 2007 | Washing Machines
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
