Bought used sony kp-43ht20 without remote so i bought 3 universal remotes and cant program any of them
  • a2109024561 Sep 08, 2010
    well i borrowed my brothers original sony remote same model and still didnt wrk i was thinking maybe it was the ir reciever
  • 736 Answers
Without trial and error there's no way to know whether or not a universal remote control will work with a particular television. If you don't mind spending money on another remote according to part store Sony miracle remote model number MR 110 will work for this television $16.95
Original remote 147685311 is $96.02 http://www.replacementremotes.com/SONIC/Buy-147685311-Remote-Control.html
The model number RM-Y908 also works with this television and is available for $29.95 at http://www.remotecontrolwarehouse.com/SONY/RM-Y908.html
Logitech Harmony 9662080403
Posted on Sep 08, 2010
  • Loretta Northcutt
    Loretta Northcutt Sep 08, 2010
    The ir sensor could be the problem. Before replacing the ir sensor in a television you can try further troubleshooting specifically completing a tv factory reset within its service menus. I do not have instructions for completing a factory reset on the television you own. The following is generic troubleshooting for remote control issues that might or might not help you:
    Replace batteries in the remote control, gently with the cleaning cloth, wipe the IR sensor located in the lower right bezel of the TV.
    2. Have the customer program the cable box or satellite remote control to work with the TV and see if this resolves the issue.
    3. Adjust backlight - if low, turn maximum level, if maximum level turn low (have customer tell you where it is set and what level they changed it to). If the OPC is enabled, temporarily disable this feature to ensure the backlight is at a constant level.
    4. If the set has the “Active Contrast” feature, temporarily disable this feature to see if there is any difference.
    5. Find out what type of environmental interferences there may be, such as alarm system, other items in the room that function with remotes, (remote controlled fans, remote controlled lights, DVD/DVR/Cable Box/Satellite Box, Stereo), fluorescent lighting (includes the energy saving CFL bulbs), sunlight, smart house (sensor controlled lights and heat) or power lines by the house. Move sources (DVD/DVR/Cable Box/Satellite Box, Stereo) to another area of the room, not in the same IR path of the set.
    6. Compact Fluorescent Light (CFL) bulbs are known to emit certain amounts of infra red radiation that can potentially interfere with electronic devices that use IR remote controls. Using CFL bulbs in sockets connected to a dimmer can result in occasional “pulsing” of light, even when the light switch is turned off. These IR pulses can be confused by the TV as IR commands and can potentially lock up the set.
    a. Using normal Incandescent bulbs
    b. Move the TV away from CFL light sources
    c. Try different CFL bulb brands. Professional Installers have recommended “Bright Effects” CFL bulbs available at Lowes for low amount of interference.
    7. IR repeaters and some PC controlled IR transmitters can interfere, and should not be placed in or directed at the IR path of the set.
    8. Have the customer move the set to a different room (if possible) of the house and see if the IR function is no longer affected.
    9. Do an industry init and see if remote works after the initialization (does it keep working).
    10. Unplug and replug set (recycle power) for at least 30 seconds.
    11. Get details of exactly when this symptom occurs (morning, night, while watching, on certain channels) and what is done to temporarily resolve the issue.
    President:
  • 1,961 Answers
It would be very helpful if you give the model and number of the 3 universal remote control that you bought.
Initial recommendation is to check first the IR sensor inside your television. Find a way to remove the back cover of your television to expose the small pc board where the IR sensor is located. The usual fault and the most common reason for inability of the remote control to communicate with the tv is because of the loose soldered terminal in the IR sensor section.
Resolder all terminal or solder joints in the IR sensor board.
Please post back if my first instruction did not work so I can give you another recommendation.
Please don't forget to rate this answer.
Thank you for using Fixya.
Alp
Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 13, 2009 | RCA Universal Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Can not get ride of the green "VIDEO" OR "LD" SYMBOL ON SCREEN
Solution was, I had to buy a universal remote control that had a button that read "display", The Radio Shack store was the only store I found that remote, it was only $9.95. I programed the remote to the TV code..easy and pressed display button...and the problem was solved.
I Thank everyone for viewing my problem..it was a local TV repair store in my area over the phone told me the solution,,Thanks again.
Jan 17, 2009 | Sony KP-43HT20 43" Rear Projection...
Can I set up a Sony DAV IS 10 using a universal remote
Look go to www.remotes.com and I am pretty sure you can order the orignal remote for youe unit with no problems! I cant find any universal that will run that unit at this time!
please take a second out and rate response!
THANK YOU!
Jan 15, 2009 | Sony DAV-IS10 System
I have a philips tv that i bought without a remote, and then bought a philips universal remote but am stuck on how to tune the channel with the remote. Very frustrating, cannot locate sticker stating brand...
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Apr 08, 2008 | Televison & Video
Cant get universal remote to work with broksonic tv
To purchase a replacement try this site
Have you tried these codes? 0236, 0003, 0463. If the remote only uses 3 # drop the first.
Mar 13, 2008 | Broksonic CTVG-5463GVC 19" TV
Dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
Jan 03, 2008 | GPX D1816 DVD Player
Sony Trinitron KV-20VM40
You can't. Best solution = buy a universal programmable SONY
remote for about 12.00.................................T.
Nov 18, 2007 | Sony KP-44PX3 44" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
