Question about Amana NDE2330AY Electric Dryer
Dryer runs fine not heating up the air flow from the vent is good reset breaker still no heat
  • Amana Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 08, 2010
Fisher Pakel dryer wont heat all the time
open round housing on left inside where the lint catcher is. clean it. if that not solve your problem then replace reset switch. hope it will help you.
May 01, 2017 | Fisher and Paykel DEGX2 Dryer
My dryer is not drying there is no air flow coming out of vent no it is not clogged it spins but does not heat the breaker is fine it seems to be a little load but other then that it is not heating?
Check the heating coil. That's what creates the heat, so it would likely be a problem with that. May not be getting power or it may just be bad and need to be replaced.
Mar 07, 2011 | GE Profile Harmony DPGT750EC Electric...
The dryer isn't providing any heat
Try Resetting your Breaker, even if the dryer is tumbling. Sometimes one breaker on a double pole trips. Also check the vent to be sure there is air flow. A clogged vent system will leave clothes wet.
Feb 27, 2011 | Whirlpool LER7646E Dryer
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Dryers
Kenmore elec dryer runs but won't heat up
Can be several problems: the heat element (coil) can be burned out, one of the over-heat sensors could be bad or overheated and did not reset ( this could be caused by poor air movement through the vent ) check your venting for good air flow. Could be a wiring connection that burned and needs repair because of the hi electric current demaned by the heat element. Goodluck, Macgivor
Jan 27, 2010 | Kenmore 64902 Electric Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
I have a kenmore washer/dryer combo.dryer runs but no heat
Try shutting breaker off FULLY!!! and then try again...
Often 1/2 trips, motor will still run, but no heat. Breaker not always evident, but click off (push fully off) and back on, and test again, also check for good air flow at the outside vent.
Oct 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
No heat from Kenmore gas dryer
Possibly a bad thermal fuse/or igniter.I'll be happy to guide you through this. archieferrarini@yahoo.com
May 22, 2008 | Dryers
Amana NDE2330AY Electric Dryer Logo
118 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
