Question about Directed SIRIUSConnect Digital Satellite Tuner Home Kit
I have had a SiriusConnect Tuner (SCH1) hooked up to an Onkyo T-4555 Tuner for several years. I recently got a message on the Onkyo Tuner "Check SR Tuner." Upon inspection of the SCH1, I noticed that there was no indicator light on. I reviewed the manual and it seems that there should be some light on as long as it has power. I assumed the unit was dead so I bought a new one and still have the same problem. Am I missing something here or did I just happen to buy another dead unit?
Onkyo TX-SR 805 flashes message "Test - < - 42" when switched on at power button.
Hello, you seem to be in technician test mode. Unplug the receiver for an hour, turn on and perform a reset by holding vcr/dvr and then on/standby. This should resolve your issue. Thank you, Onkyo USA
Mar 01, 2017 | Onkyo Televison & Video
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Jul 13, 2010 | Yamaha RX-V663 Receiver
Onkyo T-4500 FM reception problem
I have the same tuner...yes the fm and am frequencies are different there than north america...check to see if you have the "worldwide" model...there is a small switch under a small hole underneath the tuner to select the region for where it is to be used. If its not the worldwide model then i think your outta luck.
Apr 21, 2010 | Onkyo T-4555 Tuner
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Hooking Ipod to onkyo receiver
i pods use a different adapter for doing this. It plugs in the bottom using the big porton bottom and outputs the rca plugs this way. Ipods see too much resistance and protects the unit from burning out. check this out http://www.amazon.com/Logic3-iPod-RCA-Phono-Cable/dp/B00083D7WC
Feb 21, 2009 | Onkyo TX-DS595 Receiver
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Directed SIRIUSConnect Digital Satellite Tuner Home Kit Logo
146 people viewed this question
Top Directed Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Directed Audio Player and Recorder Expert? Answer questions, earn points and help others
