Question about Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker temporary stop.
  • Acer fans Sep 08, 2010
    Thanks for the reply.
    I have already reinstalled all driver, it did not fix the issue. I wonder if it is caused by loose video cable. I may try to take out the keyboard to re-secure the video cable. The display on the exerrnal LCD screen did not flicker while the netbook LCD screen flicker with colour changing.
  • Brutus Traill Oct 07, 2012
    which manufacturer of external monitor are you using? I'm having flickers with a gateway monitor...
  • 83 Answers
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Posted on Sep 08, 2010
Accere aspire 5100 desply not show
Please write in English. Thank you.
May 14, 2014 | Acer Aspire 5100 Notebook
Acer aspire z3101 u4062 can i use the monitor for another pc without running the acer aspire?
Yes just use the same connections
Processor AMD Athlon II X2 240e / 2.8 GHz
Memory 4.0 GB / 8.0 GB (max)
Hard Drive 1.0 TB
Operating System Microsoft Windows 7 Home Premium 64-bit Edition
Optical Drive DVD RW (R DL) / DVD-RAM
Graphics Processor NVIDIA GeForce 9200
Graphics Controller Integrated
Monitor Type LCD display
Oct 07, 2013 | Computers & Internet
Acer Aspire M1201: We need to find out what 2 short quick beeps signify. The unit will turn on but no video. We have already tried replacing the video card and ram and still same issue. Please help.
Have you tried connecting an external monitor and see if that one would work? Also, are you hearing any startup sound when you turn on the computer? If there is, and there is a good display on an external monitor, then it is the LCD that is causing the problem.
Sep 17, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire one will not work.
If you get a post screen with Acer written on it at startup, and the screen turns off when loading the system (Windows or Linux), then you need to reinstall the system using an external USB cd unit and the recovery disk that was provided with your Acer.
If instead the display has no screen at all , try connecting an external monitor to test the laptop.
If you get picture on external monitor, then the Aspire One has a faulty LCD ribbon cable or a faulty LCD display or inverter.
If you get no picture on external screen , then you have a faulty motherboard, possibly faulty video chipset on motherboard.
In any case check your Acer One warranty, all the faults listed are covered by Acer warranty for one year.
Contact Acer at the number listed on documentation to have the computer repaired.
Mar 13, 2009 | Acer Aspire One PC Notebook
Flickering screen on startup
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
Feb 06, 2009 | Acer Aspire 3003LCi Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
LCD problem
ok just go to Start- Settings -Control Panel - Power options -click on it inside that turn off monitor option Never u say and system stand by u make it as Never apply and say ok it will not go to stand by mode
Jul 30, 2008 | Computers & Internet
Acer 5000 screen problem
Hi again,
Have you tried lowering down the Screen Resolution and the Screen Refresh Rate in your Acer Aspire 5000's Display Properties?
If you are not able to do that, pls post back that I may walk you through the procedures.
Cheers.
May 13, 2008 | Gateway FPD2275W LCD Monitor
Acer Aspire One Netbook 8.9" Notebook Logo
925 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
