Question about Miele CVA 4066 Stainless Steel
My Miele CVA 4066 says to push in the water tank as far as possible. I do that, but keep getting the same message. The unit is only a few months old.
4 Suggested Answers
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Our Miele CVA 4066 coffee
Hello
Check that you have water available from your water line to the coffe maker,Also you may need to manually fill the tank first time around.
Here is a link for the manual check out pg 56.This is a pdf file.
http://mieleusa.com/manuals_pdf/Residential/Coffee_System/CVA4066_us.pdf
Posted on Jan 08, 2011
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
I have a built-in. There is no water coming out. Could it be the brew unit itself?
About 428,000 results (0.82 seconds) Search Results
    [PDF]Operating and Installation Instructions Coffee System - Miele
    mieleusa.com/MieleMedia/.../Coffee%20Machines/CVA6405_Coffee%2...
    Preparing multiple cups of coffee, one directly after another (coffee pot) . . . . . . 23 .....safety requirement be met. If there is any doubt, have the electrical system of ...ventilation around the coffee machine. .... nDrip tray with no-spill grid .... and out. ? Remove the lid and fill the container with fresh, cold tap water to the. "Max.
    [PDF]Operating And Installation Instructions - Miele
    www.mieleusa.com/manuals_pdf/Residential/Coffee.../CVA615_us.pdf
    Read all instructions before installation or use of the coffee system. ... there is any doubt, have the electrical system of ... The appliance must be built into cabinetry before operation to ensure that no electrical components ... towards your body or use this machine ..... Lift the water tank up and out of the ..... nothing comes out.
    Miele Products: Coffee Machines
    www.mieleusa.com/Product/List/21?filterByType=false
    24" CVA 2662 Built-In Nespresso Coffee Machine. Add to Compare Details ... 24" CVA 4066 ss Built-In Coffee Machine, with Plumbed-In Water Connection.
    Miele CVA4066SS 24 Built-in Whole Coffee Bean System ...
    www.amazon.com/Miele...Built...In.../B0025TLW6A
    Amazon.com, Inc.
Feb 08, 2016 | Miele Coffee Makers & Espresso Machines
Water isn't getting into the brew unit
Can you please clarify the problem. Are you saying that coffee no longer comes out the spouts ?
Jun 13, 2015 | Miele CVA 4066 Stainless Steel
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
Miele brew unit
You should be able to, If you can remove it and providing there are no Electrical parts, then soak in a white vinegar and water solution.
Or a Descaler.
Jan 28, 2014 | Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Miele coffee system CVA 2660 is showing fault #10 while I descale and won't let me finish the program. I restart the program by turning off the system but I get the same fault message after about 20...
F10 is a water intake fault. The are several possibilities: the pump may be defective, a piece of lime scale may have blocked a pipe, the water tank might be faulty. Most likely is the pump.
Jun 17, 2010 | Miele CVA615 Espresso Machine
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
I get the message Fill Watertank on my Miele CVA 620 Built in automatic coffee maker but the water tank is full. I think there might be a problem with the float switch but am unsure how you correct it
The float switch is a proximity sensor. There's a float in the tank that triggers the notification when it leaves the proximity of the sensor, located on the right side of the tank cavity. Try cleaning everything and make sure the float is moving freely in the tank.
Nov 25, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Miele CVA 4066 Stainless Steel Logo
179 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
