Question about RCA Lands Phones
My RCA model 25423/24 phone handset isn't working and the main phone is? The batteries are fine though because the phone is turning on and you can start to pick up a line but there is silence and then a beep saying it is impossible.
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
SOURCE: "handset. No line"
Unplugging the phone will only fix the problem temporary!
Can anyone fix it for good? I am fed up of unplugging it every day.
No line... no line no line!
Stupid phone!
Posted on May 28, 2008
SOURCE: I have a philips CD
Presumably you have 'registered' the handset to the base station - a bit fiddly, but easy enough! If you haven't a handbook, there is one here
http://www.p4c.philips.com/files/c/cd2454b_05/cd2454b_05_dfu_eng.pdf
Good luck
Jim
Posted on Oct 14, 2008
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
SOURCE: handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Posted on Apr 30, 2009
Why did my display disappear?
Possible electrolict capacitor defeated. Replace is needed.
I suggest make a electronic tech consulting. Good Luck !
Jul 30, 2014 | Compaq (252608-001) Motherboard
Base handset not working
try taking batterie out reset it 2 min then back in and unplug base might wann buy new battery also for that one
Jan 30, 2008 | Uniden Cordless Phone
Uniden TRU888 5.8 Digital Phone Display no longer lights up
I purchased this model phone as a refurb item and also had display blanking out issues. Mine related to a problem with the battery, which new batteries fixed. Try swapping the batteries between handsets and see if the fault moves to the other handset, which will prove if it is a battery problem. Otherwise, it would seem to be an internal fault in that handset. Try and arrange repair/replacement from the seller.
Jun 21, 2009 | Uniden TRU8888 Corded Phone
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Handset for ATT 5.8 GHz Cordless Telephone Model 5870
i have at & t 5870 cordless phone it is no t working. handset is dead i change the battery but still not working .please give some advice.
Mar 16, 2008 | Lands Phones
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
RCA model 25110-replacent batteries
I, too, have this model phone and love it. The headset battery barely lasted 9 months. I've been bumped around to many places including Thompson, Radio Shack, etc. I do believe Thompson (800-338-0376) has the battery for the HANDset, but they DO NOT have the battery for the headset. The HEADset battery is available through partstore.com (on the internet) (866-925-7278). This shipping document gives you the pricing info:
RCA BATTERY/ LI-POL 52707 $20.99 1 $20.99 Sub Total: $20.99 Shipping/Handling: $7.95 Tax: $1.26 GRAND TOTAL: $30.20
You may well find that the HANDset battery is available there, also. The RCA HANDset battery part number is 5-2683. You will need this to cross reference if you use partstore.com.
Warning: Radio Shack will say that they have the replacement battery. I had to send the one they ordered for me back to Radio Shack - - don't need to say more!!!
Hope this helps.
rpfanstiel@hotmail.com
Oct 16, 2007 | RCA 25110RE3 Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Lands Phones Logo
692 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
