My Maytag mod #mvwc6esww0 won't fill. It will spin only. checked input hoses and screens no problem there. The washer is only 2 1/ weeks past the 1 year warranty. From what I can determine hunting around the internet it seams to me the load sensor would have a high probability of being the culprit. My mom was opening the lid all the time for the first six months until i finally got her to stop doing it. 84 years stubborn. Anyone have the part number for this? I guess it must be located underneath the washer drum somewhere. I took apart the top and back of the washer, found the wiring diagram. Gave all the connections a look and everything is ok as far as a visual check goes. Will hunt underneath it tomorrow. Any tips would be real helpfull and appreciated greatly. Thanks
Query the water switch sensor. This sensor tells the machine it is full of water. The sensor is probably worn out. The machine thinks it is full of water and is ready to agitate the clothes. Try to replace the sensor.
Try repair clinic.com the website has a you-tube visual on how to find your model number. Helpful.
Posted on Oct 12, 2010
Our washer filled up with water and stopped working. Won't spin or drain, what do we check?
Check for a blockage either in the filter or the outlet hose or the water pump
May 12, 2012 | Maytag Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Washer wont start, it will spin but will not begin the wash or start to fill
It won't wash till the water fills to the point of tripping the water level switch. Check your screens for clogsthemobilian_3029.jpg
Service manual and more
Sep 22, 2011 | Maytag Centennial MTW5800TW Top Load...
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Maytag Washer Mod. MVWC6ESWW0 Automatic water level not working
Check your pressure hose to see if it has come off the load selection switch. If it has not then it may be the pressure sensor on the tub.
Nov 20, 2010 | Maytag Washing Machines
My maytag neptune gets a code of nf.
NF: no washer fill
Washer does not turn on water valves to fill washer with water.
Diagnosis:
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
May 05, 2010 | Washing Machines
I have a new Maytag Bravo top loader.
That means low flow. Turn up water valve. If that don't work then shut your water off take off hoses and clean the screens on the washer they are dirty that happens with hardwater
Apr 29, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
