Question about Freezers
Freezer cycling on and off rapidly
I have an old (maybe 15 years) upright Hotpoint freezer. Ever since I defrosted it 2 days ago, it has been cycling on and off about every 2 - 3 minutes. It is still maintaining a 0 degree temperature, but on a lower setting than before (2). Mainly, I just want to know if the problem might be an easy (inexpensive) fix, or is it time to get a new freezer?
  • 828 Answers
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
Posted on May 16, 2008
I bought an upright freeser but don't know how to set it is number 6 ok ? or do I have to set to a lower number.
Posted on Nov 29, 2008
  • zdasilva45 Nov 29, 2008
    what is the number we should set an upright freeser for tamperture
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore freezer gets cold and freezes but then completely dethaws itself
usually when aq defrost timer goes bad it gets stuck in defrost. I would suggest replacing this first
Mar 29, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How is it best to defrost this as it is very clogged up with ice?
Hello Cathy,
the best way to defrost that little refrigerator is obviously turn off the unit and use a blow dryer and use it to melt the frost.
GENE
Nov 30, 2011 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Nov 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Freezers Logo
465 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
