Question about Dishwashers
Hi , our dishes do not come out dry and are not clean
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Green clean dishes light blinking instead not blinking. Dishes clean, but not totally dry. I removed them from dishwasher. Clean green light continues to blink after door is shut. Pushing cancel...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 04, 2011 | Kenmore Dishwashers
Dishes don't get clean and are never dry.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Whirlpool GU1200XTLS Stainless Steel...
Not rinsing or drying,dishes not cleaned
Hi
Daniel
Nov 20, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Cloudy dishes
Hi there.
You will need to get some cleaning detergent so you can clean the jets and the internals of the machine, once the clean has been done you should end up with clean dishes.
Good luck and thanks for using FixYa!!
May 11, 2009 | Kenmore Dishwashers
Dishes don't get clean and don't dry
Hi reesbag
I'm Harvey the Master Plumber.
You're question is why the dishes don't get clean and it is not drying at all even though jetdry is full?
To begin with "jetdry" does not dry your dishes, It is a product that you can choose to use if you have a problem with spots on the clean dishes when the dishwasher is done.
Your problem is serious! If still under warranty then you're covered. If not and it has some years on it, it doesn't pay to throw good money after bad. If it came with the house it will be better in the long run to replace it. If you choose to repair, this problem doesn't lend itself to home handyman and it is likely in this case that after paying a repairman to come out you'll end up buying new anyway.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
